Anybody get the flashlight chop to work? Doesn't work for me
It works for me, but why on earth did they implement and advertise this. It takes 2, sometimes 3, hard shakes for it to work. It's much easier to just go to settings and touch flashlight.
Are you saying you can't get it? You have to hold the phone sideways and chop chop. If you're confused go to the Moto app and watch a demo within there.Ok. No chop chop for flashlight.
Quick sharp wrist chop works every time! Gotta be quick and sharp. Hiii-yahhh!!
I found I have better luck chopping it into my palm.
That snap at the end of the chop is what it's looking for. Hitting the hand stimulates that wellI found I have better luck chopping it into my palm.
