1. PowrDroid's Avatar
    Motorola Left Out Guest Mode and Multi-User Support in Your DROID Turbo’s Lollipop Update
    With Android 5.0, Google introduced support for guest accounts and additional users on phones. This is the type of feature that may not be of use to everyone at all times, but it certainly is a welcomed addition to a maturing platform, as it’s there for those who need it. When Google pushed Android 5.1 a few months after 5.0, they didn’t remove the feature. Although, if you are a DROID Turbo owner who recently updated to Android 5.1 (it’s rolling out now to all by the way), you are probably wondering where it is.
    http://www.droid-life.com/2015/07/01...llipop-update/
    07-01-2015 06:39 PM
  2. MobileBiz's Avatar
    Since they removed the ability to setup multiple profiles or guest in this vs. of 5.1., I don't think it's possible to use the droid turbo for companies using Android for Work. With Kit Kat you could install and use the app available in the play store. With android 5.0 on up your not supposed to need it and its now showing as not compatible with my device. Am i missing something?
    07-05-2015 06:17 PM
  3. PapaGary's Avatar
    At least on my Lollipopped Moto X I show: Settings>Users>Add user. Is this what you are wanting?
    07-05-2015 06:26 PM
  4. MobileBiz's Avatar
    They removed that feature in the 5.1 update for the droid turbo. I don't want to share my phone necessarily, but I believe that's why Android for Work doesn't work.
    07-05-2015 06:34 PM
  5. PapaGary's Avatar
    Wow. Bummer.
    Sorry.
    07-05-2015 10:37 PM
  6. Ry's Avatar
    Odd that it's not included.
    07-06-2015 01:58 PM
  1. Why is my home button not working on my S6 Edge?
    Last Post: 07-06-2015, 03:50 PM
  2. Why does my phone turn on?
    Last Post: 07-06-2015, 02:04 PM
  3. Why isn't my power button and home button not working on my S6 Edge?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 07-06-2015, 02:03 PM
