07-12-2015 07:53 PM
37 12
tools
  1. Eclipse2K's Avatar
    I want a dark theme. I don't want coloring book colors. i also want my battery life back. the phone was better with kk.
    Battery life on Lollipop has improved or remained the same. Not saying you're wrong but better numbers don't show out of no where unless the OS is more energy efficient. Your issues could result from a rogue application or an unknown underlying issue. If it continues, I suggest clearing the cache and last resort factory reset. One should solve the issue and you'll be back up and running!
    As for coloring book colors, huh? You're using the Turbo, right? I saw the Note 3 and the color scheme was horrible. But I find the Turbo to be far from coloring book colors.
    07-09-2015 11:09 PM
  2. mobrules's Avatar
    I have been ranting about how bad battery life was and now get to eat my words. Shut off 4g, and restricted background data last night. I will no longer complain.
    dungoyle and dmoss84 like this.
    07-10-2015 11:07 AM
  3. 1901Madison's Avatar
    How did you shut off 4g?
    07-10-2015 12:31 PM
  4. mobrules's Avatar
    In the drop down menu it's listed right there
    07-10-2015 01:52 PM
  5. mobrules's Avatar
    Here's a photo. Just touch where it says Verizon wireless and it brings up the screen to shut it off if you choose
    07-10-2015 02:19 PM
  6. Coop61's Avatar
    You are replying in the wrong forum. And to be honest I really didn't have any issues with my Sammy S5 on 5.0. If you have issues with a Samsung device you should be complaining in that forum and to Samsung. As to the Turbo., I couldn't be happier. It didn't break anything on my phone. It didn't slow it down either. Maybe I just got lucky who knows. Every issue I did run 🏃 into was caused by me and I figured out how to fix it on my own. Good luck.
    Damn I was trying to reply to some guy ranting about his Samsung updated.
    07-10-2015 06:12 PM
  7. dungoyle's Avatar
    Thumbs up for "owning up" to a misconception or mistake. Rare, and appreciated.
    mobrules likes this.
    07-12-2015 07:10 PM
  8. Eclipse2K's Avatar
    On the other hand, he completely sacrificed for battery life. I'm not sure how bad he had it but I get about 6 hours of screen time on auto brightness with WiFi and Bluetooth always on whether connected or not. Auto sync to Google services is on too.
    07-12-2015 07:25 PM
  9. AlaJack's Avatar
    My phone is better now with lollipop.
    Sent from my XT1254 using Tapatalk
    07-12-2015 07:31 PM
  10. dungoyle's Avatar
    But battery life is always compromise of something, isn't it? Not arguing, just saying. In my case, I'm lucky enough to have all day access to power, so I just take it for granted that I never have to worry about battery. I realize that a lot of other forum members don't have that luxury, and that is why they were drawn to the Turbo.
    07-12-2015 07:31 PM
  11. mobrules's Avatar
    Eclipse, I don't feel like I sacrificed at all. I just shut it all down at night. I live in a really bad 4g signal area. Usually 1 bar. And signal around - 120. My rants were mostly because they removed permission for apps like Tasker to automatically control this for me. I used the paid version because it worked so well. I just now have to manually shut stuff down to get decent battery life.
    I do still feel this is a money maker for big red. There will be soon people complaining they went over data plans. Some of that data being used at night. Some will be forced to increase plans. I have UDP still so I don't care too much.
    I'm not willing to give up the plan even though I have a weak signal. In fact us cellular has a really fast signal in my area. 5 times faster than big red. But I just can't give up the plan.
    07-12-2015 07:44 PM
  12. Eclipse2K's Avatar
    Ah okay, I missed the part where you had used Tasker and that you're in a bad signal area. Makes sense now.
    True, and I didn't consider a weak signal either.
    07-12-2015 07:53 PM
37 12
  1. HTC M9 lollipop issue?
    By bren5666 in forum HTC One M9
    Last Post: 07-18-2015, 02:18 PM
  2. How do I add a permanent signature in text messages on my Galaxy S6 Active?
    By AC Question in forum Samsung Galaxy S6 active
    Last Post: 07-11-2015, 11:42 AM
  3. Replies: 5
    Last Post: 07-08-2015, 03:43 AM
  4. Why do registration message comes in every start?
    Last Post: 07-08-2015, 01:05 AM
  5. What is the best alternative to sms software in India?
    By Arivanantham Gangamirtham in forum General Help and How To
    Last Post: 07-08-2015, 12:35 AM
