1. TucsonDave's Avatar
    I've got my Droid Turbo w/Lolipop in an Otterbox commuter case. I have searched and can't find solid info on OTG USB support. Do any of you have a working set up that will let you plug a micro USB stick directly into the phone and be able to read files, music, ect? Do you have to use an OTG adapter? I'd love to take advantage of having all my music available without maxing out the phone's memory.
    Any help is greatly appreciated.
    Dave
    07-08-2015 10:08 AM
  2. Martin Ferreyra's Avatar
    Yeah, with OTG you will ahve that advantage I suggest to you to use the ES file manager to manage the pendrive with that files from there.
    jesta192 likes this.
    07-08-2015 11:02 AM
  3. TucsonDave's Avatar
    Is a file manager a necessity? Or can I just connect a USB stick via OTG and see the files in the appropriate app, for example will the music be in the default music player? Are there any USB sticks that have the OTG functionality built into them, thus eliminating the need for two pieces of hardware? I think another requirement for me would be that the mini USB connection be long enough to allow it to fully seat with my case on the phone.
    07-08-2015 11:25 AM
  4. ryanidcomm's Avatar
    File manager is necessary.
    yes they make usb drives with a micro adapter so it plugs right into your phone and your computer.. I own one its about the size of a dime.
    OTG cables come in all different sizes
    Ive heard issues with people getting music from an external memory to work with the new google music... worst case.. just download a simple player.
    07-09-2015 01:46 AM
  1. Replies: 3
    Last Post: 07-08-2015, 08:40 AM
  2. OTG and Extension - not working correctly. How can I get it working?
    By James Freeman6 in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-08-2015, 07:58 AM
  3. Replies: 0
    Last Post: 07-08-2015, 04:11 AM
  4. I need an android application that can lock the menu butoon
    Last Post: 07-08-2015, 01:41 AM
  5. Samsung s3 wet diplay problem help please!
    By khaled saidi in forum Ask a Question
    Last Post: 07-08-2015, 01:35 AM
