1. procrastination's Avatar
    I'm coming from a MotoX and I want the notification sounds from that device. Can these be downloaded?
    Sent from my XT1254 using Tapatalk
    07-08-2015 10:16 PM
  2. Einsteindks's Avatar
    They can be copied from the system folder, then put in a folder labeled media of your new phone...I think.
    procrastination likes this.
    07-08-2015 10:21 PM
  3. russel5150's Avatar
    They should be on zedge, if you havent used it before its great for finding sounds from other phones, even the old ones.
    procrastination and adayoff like this.
    07-08-2015 10:24 PM
  4. AMTrombley0924's Avatar
    What I've done is google search "insert desired phone" system dump. Usually when a new phone comes out, devs or the community in general will pull the stock wallpapers and sounds and publish them for people like you. I have a few like the M8 and Nexus devices
    Sent via my DROID Turbo via Mr. Universe's Signal...because you can't stop the signal!
    07-09-2015 06:39 PM
  1. Invitation to a free test of the first dedicated Android Wear Smartwatch keyboard
    By Touchone Touchall in forum Android Wear / Wear OS
    Last Post: 08-18-2015, 08:26 PM
  2. Replies: 2
    Last Post: 08-05-2015, 07:03 AM
  3. Replies: 1
    Last Post: 07-08-2015, 08:59 PM
  4. Why can't I hear any media sound on my Galaxy Note 3?
    Last Post: 07-08-2015, 08:10 PM
  5. Replies: 0
    Last Post: 07-08-2015, 08:03 PM
