1. Billy Bixby's Avatar
    My wifi signal has been significantly improved since android L. I used to frequently drop wifi while on my back patio. It hasnt happened once since lollipop. Anyone else seeing this?
    adayoff likes this.
    07-08-2015 10:27 PM
  2. russel5150's Avatar
    What i was seeing is if i hadnt messed w my phone in a little while, when i got on it and tried to open an app it would just sit and load and i would have to close it and re open it, like the wifi was trying to reconnect.
    Since lollipop i haven't had this issue, its fast and doesn't
    lag
    07-08-2015 11:54 PM
  3. Eclipse2K's Avatar
    I have ThundeROM installed now. Anyone tried both? Any preferences?
    Are you still using the same frequency band? I've never had issues and still don't. I always use 2.4Ghz since its range is further than 5Ghz but its slower. Just wondering if Lollipop got better or if you had a change.
    07-09-2015 06:48 AM
  4. Billy Bixby's Avatar
    Didnt change a thing and still have not lost wifi on the back patio. L has been great so far.
    07-10-2015 09:52 PM
  5. eprindes's Avatar
    Dropped connection all the time with KitKat, so frustrating. Ever since lollipop no issues at all
    adayoff likes this.
    07-10-2015 10:22 PM
  1. Replies: 15
    Last Post: 07-27-2015, 03:44 PM
  2. Anyway to Update to Lollipop through ADB?
    By deesugar in forum Motorola Droid Turbo
    Last Post: 07-14-2015, 06:25 PM
  3. WIFI is completely jacked
    By TheOpusFuller in forum Samsung Galaxy Note 4
    Last Post: 07-09-2015, 06:56 PM
  4. Replies: 1
    Last Post: 07-08-2015, 11:33 PM
  5. Weird Wifi Issue
    By av1atrx in forum Samsung Galaxy S5
    Last Post: 07-08-2015, 06:12 PM
