08-01-2015 09:50 AM
36 12
tools
  1. smokie11's Avatar
    For many is already too late, you installed 5.1 believing the hype that latest means greatest and found out that 5.1 is not better than 4.4.4, simply different. You found out some of your apps don't work, your battery life took a hit for the worse or even your hardware does not perform as well as it did on Kitkat 4.4.4. If you installed the OTA for 5.1 and you are happy, this is not directed at you; just continue to enjoy your new OS. I have taken the time to read from many different sources and viewed several videos on You Tube that test side by side Kitkat 4.4.4 vs LP 5.1 and it shows conclusively that Kitkat outperforms LP is just about every category that can be measured or seen with your own eyes. I also realize that some on kitkat may be experiencing a specific problem that they believe or hope LP will solve. This post is not designed to tell anyone what to do or not do. I advised caution, patience and research.
    If you know for a fact that LP will offer you something specific that you need take the plunge but at least take the time to check what LP will mess up that you are now enjoying on Kitkat, the information is out there easily found, in closing: if you are sitting on the fence and have not yet taken the 5.1 OTA read and view videos so when you make your decision at least you will know what you will be getting and losing.
    07-12-2015 01:25 PM
  2. dungoyle's Avatar
    Obviously, you have had a poor OTA upgrade experience. However, reading the majority of the posts on this forum would seem to be contradictory to your own experience. In no way am I de-emphasizing your misfortune; but I do think you could have toned down your warning. After all; all OTAs are a bit of a roll of the device. I may have missed it, but I didn't notice if you tried a factory reset -- no, you shouldn't HAVE to do that, but it's an option that regularly yields positive results.
    Not only have I been quite happy with my own upgrade experience, but I experienced increased benchmark results after the upgrade; comparing 3D Mark and Quadrant immediately before and after the update.
    hub1 likes this.
    07-12-2015 05:44 PM
  3. Davidoo's Avatar
    Well, I can see with my own eyes that I get better battery life on Lollipop, and that my apps open faster. I've also seen bench scores posted with games showing they get higher scores with L than KK. After all, it is the internet and you can always find information to support your opinion if you look long enough.
    07-12-2015 05:51 PM
  4. dungoyle's Avatar
    This is true, but regretfully supports both sides of any discussion. In my case, I fall on the positive side of the upgrade as it relates to stability and performance. Many others have complained about the GUI and behavioral changes, and those are legit beefs. I'm on the fence here and there in that department as well, but consider the overall update an improvement -- personally, of course.
    smokie11 likes this.
    07-12-2015 06:00 PM
  5. smokie11's Avatar
    I have not installed LP 5.1 in any form. I am glad you had a positive experience and I am sure many others have also; just like many are very unhappy with the results. If you read my post carefully you will see all that I advocate is making an informed decision, once you take the 5.1 OTA you are stuck with it, my warning was based on research outside this forum as well; not my own misfortune, I advised " caution, patience and research " I am truly glad your experience went well and I am sure many others went well also...I can't stand white backgrounds, yes that is just simply a preference on my part.
    c4400 likes this.
    07-12-2015 06:03 PM
  6. smokie11's Avatar
    I am very happy with your positive experience, remember I wrote that my caution did not apply to the happy customer. I advocated making an informed decision, never said don't do it.
    07-12-2015 06:09 PM
  7. dungoyle's Avatar
    Thank you for (politely) correcting my misunderstanding of your post. You are right; your didn't state you upgraded. However, having said that, your post was rather venomous, and really led me to believe that was the case. After all, most folks don't complain or intently make such statements unless they are directly harmed; so while again I do apologize, you might see my mis-interpretation.
    I would say that your warning is well founded, while still being exaggerated based on my personal opinion, and the overall feedback in this forum. It's a damned shame that Android has not reached the point of a roll back option (which indeed I personally believe IOS, Win Mobile and and Android should have all evolved to by now), so that you could see for yourself whether or not this upgrade is for you. Cheers!
    07-12-2015 06:19 PM
  8. smokie11's Avatar
    No apologies needed, you stated your position in a friendly respectful manner. I could have just said: do a little research before you take the plunge once on OTA 5.1 there is no rolling back if you don't like it. Is all good we are here to help each other: if one does 5.1 and it does not turn out well... you know.
    07-12-2015 06:35 PM
  9. smokie11's Avatar
    This is just curiosity on my part, is Lollipop much better than this. Antutu.
    Attached Thumbnails Why you should pause and read before installing Lollipop 5.1-screenshot_2015-01-01-14-33-28.jpg
    07-12-2015 06:44 PM
  10. mobrules's Avatar
    Knowing what I know now I would not have upgraded. I will live with it. But given the choice, with better knowledge, I would have declined. But I have no one to blame but myself. I chose to install.
    adayoff likes this.
    07-12-2015 06:48 PM
  11. dungoyle's Avatar
    Why you should pause and read before installing Lollipop 5.1-screenshot_2015-07-13-18-45-26.jpg Not a big difference, but honestly, I wouldn't have been surprised if my score was lower -- I run a LOT of apps, and have 4 screens with numerous widgets, and a main screen packed with folders. I just realized, I still have my hotspot on from earlier at work today -- woops! I imagine there are some streamlined users out there that can post a much better number than me.
    paulmike3 likes this.
    07-13-2015 06:00 PM
  12. maxman1's Avatar
    I had a bump of +/- 1500 on my Antutu score going to 5.1 with no other changes. It's of no particular significance other than, slight improvement which beats none or a regression.
    07-13-2015 07:20 PM
  13. NoahForeman's Avatar
    There is a way to actually test 5.1 and go back to 4.4.4 if you please. Basically you grab the official full image and only flash those items which can be downgraded after an update, and leave the secure items on 4.4.4. It's how a lot of us now have 5.1 rooted, but it works with stock signed images as well.
    The commands once you extracted the images would be:
    fastboot flash logo logo.bin
    fastboot flash boot boot.img
    fastboot flash radio radio.img
    fastboot flash recovery recovery.img
    fastboot flash system system.img
    fastboot erase ddr
    If you don't like 5.1 after that, you can just flash the FULL 4.4.4 image using RSDLite and go back
    (I take no responsibility to what happens to your device, take your own risks, yada yada yada )
    07-13-2015 09:00 PM
  14. vzwuser76's Avatar
    What you said could be true of any update. Have you ever heard of an update that didn't have some people with apps that didn't work on the new update? Or battery life or hardware performance that didn't take a hit after they updated? This happens with every device with every update. There's always the risk that you could be in the group that has issues, but the only alternative is to not update your device. And then down the line some apps won't work anymore, and battery life and performance could suffer as well.
    But the biggest point to consider, IMHO, is that the ones with issues will make the biggest noise. It's rare that you see people just chiming in and saying, everything's great, no problems at all on a support forum. Unless of course the ones with issues complain and others then share their better fortune. But otherwise most of what you hear on a support forum are the problems people are having, not that they're doing peachy.
    I agree that people should be cautious, but in reality what you're talking about isn't isolated to anyone update or phone model. There always has been a risk when you update and there always will be.
    07-13-2015 10:00 PM
  15. Billy Bixby's Avatar
    Slight improvement in battery life after my upgrade. Loving android L.
    07-13-2015 10:25 PM
  16. maddiealan's Avatar
    Well, I never post, but I lurk all the time to get information. I read every last comment when we were waiting for the 5.1 update, and I too was pissed with all the waiting. Now, I have to say that I'm loving Lollipop! I did not clear the cache, I did not do a factory reset, and everything is running smoothly.....faster than before.....and my battery is great. Just as good if not better! My only complaint, like others, is the pain in turning data on and off manually, but other than that, I'm very happy. I felt I needed to post my positive experience.
    07-13-2015 11:28 PM
  17. this_is_nascar's Avatar
    Here's my issue. I've been involved in IT for 30+ years. We never implement an upgrade, especially an OS upgrade, without being able to go back. That's just the way it is. I hate the fact that smartphone technology does not allow for an easy and seemless back out to the prior OS. If that capability was there, I'd upgrade right now in a heartbeat. Instead, I'll wait a bit longer.
    Sent from my Droid Turbo 64-gig from Tapatalk.
    07-14-2015 05:46 AM
  18. zen45's Avatar
    im fairly new to the android os and I have a droid turbo . im having a few problems with contacts, on my old phone you pulled down a menu when some one called and just added it to your contacts, with the droid it isn't that simple lol . but that's part of the learning curve ! now on kitkat I could not get wify to connect at all it just wouldn't accept my password after I upgraded to lollipop it connected with out any problem's ive done two factory re sets so far ( I only have about 3 programs I installed ) so its not a big deal ( im over 70 so the grey mater is a little slow ) I just wish they wouldn't make the phones smarter until the people using them catch up lol
    07-14-2015 07:35 AM
  19. smokie11's Avatar
    I was looking at the Antutu Benchmarks and it seems that the LP 5.1 developers were paying close attention to GPU 3D graphics. I don't play video games but I believe those that do will see an improvement with LP.
    07-14-2015 01:16 PM
  20. leehardballer12's Avatar
    Personally, I just like how the phone works now on 5.1. I think it looks better and performs better now as far as notifications, and accessing settings and toggling things on and off with the double swipe down. The lock screen notifications are actually useful now. Mostly, I find myself doing a lot less swiping and tapping and going back and forth now. I think 5.1 has much better flow as far as navigating the device and moving across numerous open apps.
    cooper_m22 likes this.
    07-14-2015 09:23 PM
  21. deesugar's Avatar
    Honestly rooted phones are a lot safer to work with. With a rooted phone you can have as many backups of the phone as you want, like a save in Apple's Time Machine and then go back to that save if something goes wrong. Having a complete backup like that is way more reassuring and easier to deal with then the non-rooted BS.
    Google should really offer a way to backup up your phone before an update or for safe keeping. It's old technology that was available a long time ago and it should have never been phased out.
    07-16-2015 12:21 PM
  22. doogald's Avatar
    No, it's definitely less safe if you care about the security of your data. (And remember the data on your phone is not just private info about you, but also about your contacts and people you correspond with as well.) If a phone is rooted it's going to be far easier to steal data if you lose your phone or it is stolen. Trivially so in most cases. And if a phone is rooted, it is going to be far more vulnerable to malware.
    Better answer. <rant>Android should have a backup and restore process that allows you to factory reset and bring it right back like iOS does. Basically, backup your data and settings, then, after a factory reset, restore your settings, reinstall your apps from the play store (that part Android does), and then restore your app data as each app is restored. The inability to restore most settings in particular is a pain (BT pairings, ringtones, notification tones and volumes, etc.) Every single setting you can get to from the settings app should be restore-able.</rant>
    Android has never had that.
    DatabaseMX likes this.
    07-16-2015 01:14 PM
  23. deesugar's Avatar
    I'm afraid you don't know much about root because you can turn it on and off (once you're rooted) simply with any of the many apps or widgets available and only use the root functionality when you need to do something. You can also set specific permissions for your data and/or apps.
    07-16-2015 01:25 PM
  24. doogald's Avatar
    But once you set permission for an app like Chrome, you've set it and most people are unlikely to go back to turn it off. I rooted my first Android phone in May 2010, so I think I know a thing or two about it.
    But, I'll just link to someone who knows a lot more about it than you or me: [Q] security of rooting apps and custom roms - Post #3 - XDA Forums
    07-16-2015 04:19 PM
  25. deesugar's Avatar
    Ha, that's funny you chose to link to Jcase! He's one of the most active members out there rooting the Moto phones including some of the Droids
    First of all if you're going to go the paranoid route then it's not safe to put your personal information on anything that connects to the Internet stock or rooted. Don't use the cloud, write everything on paper and lock everything in a safe. Also there's no guarantee you wont have exploits and problems with a stock phone and stock updates. But there's a reason why people like your friend Jcase root phones. It gives you the awesome ability to customize your phone and allows you to:
    1. Remove Preinstalled Crapware and bloat
    2. Back Up Your Phone for Seamless Transitions
    3. Block Ads in Any App
    4. Boost Your Phone's Speed and Battery Life
    5. Automate Everything
    6. Unlock Hidden Features and Install "Incompatible" Apps
    7. Truly Own Your Device
    And yes with great power comes great responsibility but you also get to learn a lot about Linux and how phones work. It's the most fun way to learn about programming, how OS's work and the interaction between hardware and software. You can brick your phone but nowadays there is no "tech" in the back of a Sprint or Verizon store to say it's due to rooting or it's your fault. They just send you a new phone, I should know I just got my new phone last week from trying to sideload 5.1 to see if I could reset the Force LTR bug.
    But at this point it just comes down to personal choice. Those who are happy to have Google, Verizon or Moto to tell them what their phone can do and what software will be loaded are free to do so. But there is a big group of people who like to tinker, customize and push the possibilities of what their phone can do.
    It's the same as some people like to turn wrenches and soup up their cars and those who prefer to leave it stock and take it to a mechanic when something goes wrong.
    07-16-2015 05:06 PM
36 12
  1. Why is the screen on my Samsung tablet dimming?
    By AC Question in forum More Samsung Tablets
    Last Post: 07-12-2015, 03:03 PM
  2. Replies: 1
    Last Post: 07-12-2015, 01:31 PM
  3. Why doesnt android have gay emojis?
    By Brooklee Bernard in forum Ask a Question
    Last Post: 07-12-2015, 01:30 PM
  4. Replies: 0
    Last Post: 07-12-2015, 12:45 PM
  5. Replies: 0
    Last Post: 07-12-2015, 12:15 PM
