1. cdmjlt369's Avatar
    Recently updated to lollipop and was wondering if anyone who was having wifi issues has done a FDR and if so did it resolve issues.
    07-13-2015 07:00 AM
  2. russel5150's Avatar
    I was having wifi issues before lollipop, when i got the update i did a factory reset right away (i usually do) and the wifi issue went away. I cant honestly tell you if lollipop fixed it or the reset did.
    I would recommend a reset if you can set your phone back up the way you want it. Just be sure to save everything you want to a pc or something first
    07-13-2015 07:40 AM
  1. Wifi connection lost and browser gone, what could the problem be?
    By AC Question in forum Android 4.4 KitKat
    Last Post: 07-17-2015, 11:36 PM
  2. Why doesn't my LG G3 pick up the strongest WiFi signal?
    By Pieter Keirsgieter in forum LG G3
    Last Post: 07-15-2015, 08:04 AM
  3. Linksys EA6350 (AC1200+) slow wifi only on Android devices.
    Last Post: 07-12-2015, 09:09 PM
  4. Why isn't my remote shutter paring with my Droid Turbo?
    By AC Question in forum Motorola Droid Turbo
    Last Post: 07-12-2015, 05:16 PM
  5. Why do my emails no longer work on my Droid Turbo?
    By novaarch in forum Motorola Droid Turbo
    Last Post: 07-12-2015, 12:59 PM
