1. Cybric11's Avatar
    My notification volume is in high but I can barely hear them. Anyone else having this problem? Ringer is fine.
    mkhol likes this.
    07-15-2015 08:50 AM
  2. PowrDroid's Avatar
    I have the opposite effect, seems my notification sounds are louder. Also speakerphone, while always strong, seems even louder with Lollipop.
    If you haven't done so already, check your volume setting for notifications.
    07-15-2015 10:18 AM
  3. Cybric11's Avatar
    Thanks. It is ask the way up.
    07-15-2015 12:15 PM
  4. jessegio34's Avatar
    I only have that with my Facebook notifications. Sometimes they are loud and then very low. Very weird.
    Sent from my XT1254 using Tapatalk
    07-15-2015 10:59 PM
  5. mkhol's Avatar
    I am having the same issue. Ringer is fine, all other notifications I can hardly hear, and yes, the volumes are up on all of them.....facebook is bar far the worst.
    07-16-2015 12:00 PM
  6. Eclipse2K's Avatar
    Do you use Bluetooth? After listening to media, be sure to exit out of it before you turn the headset off. Not doing so will mess with notification volume until a reboot.
    07-20-2015 03:48 AM
  1. Replies: 2
    Last Post: 07-16-2015, 04:25 AM
  2. What can cause my mobile data not to work?
    By Andredab in forum Ask a Question
    Last Post: 07-15-2015, 01:20 PM
  3. GS5/Lollipop Bluetooth Problems! [Honda Civic 2013]
    By jdub412 in forum Android 5.0 Lollipop
    Last Post: 07-15-2015, 08:47 AM
