TL;DR: After the 5.1 upgrade, my automation apps can't turn off mobile data anymore. That was how I was stopping beeps while I was sleeping. How do I get the phone to go completely silent except for phone calls overnight?
My goal: phone goes silent during set night hours; the only thing that can get it to make noise is a phone call or alarm. It would also be convenient to be able to toggle that mode on or off manually. Anyone else have a simple solution for this sort of thing? I need it to be 100% effective in shutting up every single app and beep, and so far the only way I've found to do that is to turn off all data connections.
Would the new 5.1 "Downtime" option fix this problem? On the Interruptions settings page, I could set only phone calls to be priority interruptions, and then set only priority interruptions to come up during quiet hours. Would that really stop all apps, or just those that play nice? Can't seem to trigger that downtime time manually, though.
I've been using
Battery drain analyzer free to set up a silent mode at night. It has a simple night and day setting, where at a set time, it can turn things off or on. So every night at bedtime, it turns off wifi, sync, and mobile data, so the only things that could really happen are phone calls and text messages. (I'd like to silence texts, too, but have not figured that out.) Then it all comes back on at a set time in the morning. Simple and straightforward -- that's all I want. It's also convenient to be able to hit the "night" button if I go to bed early or sleep past the usual wakeup time, or to hit the "day" button if I wake up early.
But with the update to 5.1, that app doesn't automatically turn off mobile data anymore. I've also noticed that my
Power Toggles notification bar button no longer turns off mobile data with one click; instead it sends me to the settings page for mobile data, where I click again to turn off mobile data. There's no option in
Automate It, either.
I'm guessing that this is a settings change in 5.1. Before I start fiddling with other apps, has anyone else had the problem that they're not able to automate turning mobile data off anymore?
