1. ascene's Avatar
    After much consideration, and annoying "xxx has stopped working," I finally factory reset my phone. Wiped everything completely.. Other than Google Search which has refused to understand that I don't care what my previous searches are.. But, I need your input on :
    -must have applications.
    -apps to disable.
    -anything else that is convient.
    Please and thank you!!!
    07-17-2015 08:58 PM
  2. PowrDroid's Avatar
    See this thread for apps you may disable :
    http://forums.androidcentral.com/sho...d.php?t=455536
    DROID TURBO: Apps OK to disable
    As to must have apps, I'd say Tapatalk, obviously, and ES File Explorer. ES File Explorer can do a lot of tricks. My favorite is to transfer files between Turbo and PC without the USB cable. Instructions here:
    http://www.cnet.com/how-to/share-fil...file-explorer/
    Google Drive is already on your phone. Since I've discovered you can use it to scan documents into pdf files it's being used a lot more.
    Not "must have" but I like Feedly for getting my news, Flixster (includes Rotten Tomatoes) for movie reviews, GSam battery monitor, Wifi Analyzer to measure Wifi networks RealCalc for a scientific calculator. Believe it or not, but I'd say the Verizon Messaging + app is the best text messaging app.
    07-18-2015 09:34 AM
  3. Bagua's Avatar
    GSam battery monitor and Battery percent enabler. One to moniter battery usage, the other for percent of battery remaining on the status bar, no additional icon.
    Sent from my XT1254 using Tapatalk
    07-18-2015 07:54 PM
  4. GeodudeFFP's Avatar
    Cerberus app...
    07-19-2015 04:10 AM
  5. ascene's Avatar
    I've been using Drive a lot. But any others? I want to be able to customize in a way with useful apps. I hate gallery and photos. And play music.
    07-20-2015 05:28 PM
  1. Lock Screen Help
    By lacit1707 in forum Samsung Galaxy S6
    Last Post: 07-20-2015, 03:39 PM
  2. Why does my phone only go into recovery mode?
    By aniq52 in forum Samsung Galaxy S5
    Last Post: 07-18-2015, 11:25 AM
  3. Replies: 0
    Last Post: 07-17-2015, 08:28 PM
  4. Replies: 1
    Last Post: 07-17-2015, 07:05 PM
  5. i have a blu neo 3.5 i need help in a big way
    Last Post: 07-17-2015, 02:00 PM
