1. flybub's Avatar
    Hey all. Has anyone noticed their speaker volume being inconsistent since lollipop? Most notably is the alarm. There have been days that it is very loud and others I had to make sure the volume was turned up because it was pretty quiet. Luckily I was up this morning and waited for my alarm to go off. It went off but it was very quiet, if I was still asleep there is no way I would have heard it which is opposite yesterday because it woke my wife up it was so loud. I have changed the tone but it hasn't made any difference. Anyone else have this?
    07-18-2015 07:39 AM
  2. Eclipse2K's Avatar
    The only time I've seen is an issue with Bluetooth. If I listened to music and turned the headset off before I stopped the music, all of my notifications would be low until a reboot.
    Is it possible you're doing this? You would need to turn the music off then the Bluetooth headset.
    07-20-2015 04:43 AM
  3. MA2GA28's Avatar
    Not even sure it is a BT issue. I noticed the other day that, somehow, my call ringer volume was very low for no reason at all. I always keep my ringer at max volume, so no idea how the volume setting got so low. I use the priority setting during the night, so wondering if there is a bug somewhere that is not properly resetting tone volume for some reason.
    07-20-2015 10:00 AM
  4. Eclipse2K's Avatar
    I use Priority every night with no issue. But it could always be a bug.
    07-20-2015 04:18 PM
  5. flybub's Avatar
    Thanks for the suggestions. I've been using a Bluetooth Stereo lately and my bluetooth is still on (stereo however is off). I also us Priority at night so I'll look into that as well. Thanks again for the help.
    07-20-2015 05:57 PM
  6. Eclipse2K's Avatar
    You can leave Bluetooth turned on at all times. The issue I've noticed is that if I listen to music but turn off the Bluetooth source (headset, speaker) before I shut down my music application, the notification volumes are much lower until I reboot.
    07-20-2015 07:52 PM
  1. Replies: 4
    Last Post: 07-22-2015, 08:06 PM
  2. Why doesn't my Moto G2 connect to my pc?
    By AC Question in forum Moto G
    Last Post: 07-18-2015, 04:10 AM
  3. Why isn't Google Now available in my country?
    By cadot in forum HTC One M8
    Last Post: 07-18-2015, 01:58 AM
  4. Replies: 0
    Last Post: 07-18-2015, 01:45 AM
