1. silverback's Avatar
    So, using the Moto screen that displays notifications, I swipe to unlock, then get another unlock for the main lock screen. Ergo, I have to swipe twice to unlock. Is there any fix other than no unlock? This leaves the phone open until the Moto screen takes over.
    I could stand to get it back to the 4.4 method...
    07-20-2015 05:44 PM
  2. Clocks's Avatar
    The power button will take you straight to the pin screen or swipe screen (if you have to pin) won't it?
    07-20-2015 07:07 PM
  3. flybub's Avatar
    I think this is a bug because I notice it as well. It doesn't happen for every unlock but it happens every once in a while.
    07-20-2015 07:20 PM
  4. Mikey D_PhD's Avatar
    It's not a bug. It depends on the length of time that you have before the pin, pattern or password lock is required.
    The moto display is meant to give you quick info so that you determine whether to unlock the phone. If you have a pin, pattern, or password, you still have to enter that for full functionality.
    As stated before, the power button will take you direct to the lock screen.
    07-20-2015 09:13 PM
  5. silverback's Avatar
    Everyone said the home button should take two taps to return to the home screen, and I wish that bug would reappear too. This one is a bug that needs to come back then. The update detracted from functionality. Ugh.
    07-20-2015 09:15 PM
  6. Snareman's Avatar
    I've noticed this too and find it annoying. Give me one swipe to the home screen.
    07-20-2015 11:42 PM
  7. silverback's Avatar
    YES!
    07-21-2015 07:37 AM
  8. jesta192's Avatar
    I don't have secure unlock enabled at all, and I occasionally see the Android lock screen after the Moto lock screen dismisses. It seems that this is probably just lag, as I've seen the Android lock screen dismiss on its own if I give the phone an extra couple seconds. Because of this, I'm hopeful an update to the Moto app might solve the problem.
    Sent from my XT1254 using Tapatalk
    07-21-2015 07:34 PM
  9. Serieswon's Avatar
    Waring to new Turbo owners! DON'T ENTER A PASSWORD, PIN OR SWIPE PATTERN (in a Droid Turbo)/UNLESS YOU PLAN TO USE ONE FOREVER.
    NO WAY TO GO BACK TO PASSWORD FREE STATE MOTOROLA KNOWS. So now I have to swipe the homepage lock and the password page too. Bummer!
    07-23-2015 12:22 AM
  10. Serieswon's Avatar
    I was able to get rid of the password pattern thanks to someone on another thread. Very strange way to do it. Cleared credentials see attached screen shot.
    07-23-2015 01:03 AM
  11. jrmt077's Avatar
    Yes I see the same bug, I too have no secure unlock, its intermittent as was explained by others. Its the only glitch I have experienced from the 5.1 update. Will see if the new patch update fixes tonight.
    07-23-2015 08:18 AM
  12. ryanidcomm's Avatar
    Oy one of the man reasons i haven't updated .. as a moto fan boy i was over joyed when we upgraded from gingerbread to ICS (razrMAxx) b/c it got rid of the Double lock screen.
    07-23-2015 12:19 PM
  13. silverback's Avatar
    Well, it appears the recent hotfix got rid of double unlock. Cool.
    07-23-2015 12:31 PM
  1. Replies: 4
    Last Post: 07-23-2015, 04:49 AM
  2. Data issue in Lg g2 ls 980 Sprint's unlocked in India
    By sivasankar maddi in forum Ask a Question
    Last Post: 07-20-2015, 11:08 PM
  3. How do I unlock my ZTE smartphone from the FBI virus?
    Last Post: 07-20-2015, 06:12 PM
  4. unlock is stuck on alternative password
    Last Post: 07-20-2015, 12:50 PM
  5. How can I unlock a Samsung phone, lost pin number?
    Last Post: 07-20-2015, 12:06 PM
