1. conan1071's Avatar
    am thinking about the droid turbo, however I love having voice and data at the same time on my maxx. I get decent LTE around Chicago, some areas its 3g or 1X only. Does the turbo get good LTE? If I use advanced calling, I can use voice and data at the same time, if not then I can't?
    07-21-2015 09:24 AM
  2. Einsteindks's Avatar
    Turbo is a slightly more of everything the Maxx is.
    07-21-2015 09:30 AM
  3. mobrules's Avatar
    Conan,you should have no problems. I remember you from RMHD forums. As long as you live or travel in a decent 4g area you shouldn't have issues.
    07-21-2015 09:40 AM
  4. doogald's Avatar
    Yes, that's correct. However, think of it this way: even on the Maxx in a 3G or 1x area, you can't do voice and data at the same time. The only advantage the Maxx has is that it will hold a phone call when you go from an area with good LTE to one with only 3G. For now, advanced calling will drop the call when you lose LTE.
    07-21-2015 11:18 AM
  5. mobrules's Avatar
    That is correct. I don't use advanced calling because of this. I live wayyyyyy outside Chicago and anywhere I travel can switch from 4g to 3g several times. I never activated it because of this. The closer to Chicago the less this will happen.
    07-21-2015 11:29 AM
  6. Eclipse2K's Avatar
    Depends where you're at. I'm in Will County and have Advanced Calling activated and it works everywhere I go.
    07-21-2015 10:33 PM
  7. Toes Up's Avatar
    I am in Lasalle County, which is way out in the sticks too and I have no problems with AC.
    07-22-2015 03:59 PM
  8. Bagua's Avatar
    In Mchenry county, using AC, 3 bars of 4g, I'm in Harvard not the town itself but in the out skirts of town. Going into the city my signal gets stronger and always 4g. The only issues with reception tend to be on the south side of the city.
    Sent from my XT1254 using Tapatalk
    07-22-2015 11:31 PM
  9. Brian Singleton's Avatar
    My LTE signal strength is great here at home on the North Side. Only place I have any issues at all is deep in my office downtown.
    07-23-2015 05:14 AM
  10. dcallan's Avatar
    I have no issues in and around Chicago. LTE is strong in the loop, Cook County, Lake County, and DuPage County. This is where I am usually traveling. I have dropped maybe 3 calls since the original LTE update in January.
    07-23-2015 07:25 AM
  1. Why has Google Voice Typing become so slow and laggy?
    Last Post: 07-12-2018, 03:18 AM
  2. LG G4 no 4G LTE Data Verizon
    By Schnitzer21 in forum LG G4
    Last Post: 12-27-2015, 12:21 AM
  3. Replies: 1
    Last Post: 07-21-2015, 11:33 AM
  4. Why can't my unlocked S6 Edge select LTE?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 07-21-2015, 08:50 AM
  5. Replies: 0
    Last Post: 07-21-2015, 08:17 AM
