1. The Lip's Avatar
    In Kit Kat, when I looked at a contact, all of the information for that contact was displayed, including multiple phone numbers. With Lollipop, contacts that have multiple phone numbers now only display one phone number and there is a "see all" button that I need to push to see the additional phone numbers. I have tried to find a setting that would make it so all of the information was displayed but can't find one. Other than downloading a new contacts app, anybody know of a solution?
    07-22-2015 08:42 PM
  2. kmf1's Avatar
    I've noticed that also. A big step backwards. Especially that it doesn't show the mobile number first.
    Sent from my XT1254 using Tapatalk
    07-22-2015 08:57 PM
  3. Bitterman's Avatar
    Also not a fan of the way contacts are displayed in LP. It's a little thing but miss the way KK used to show your total number of contacts too.
    07-23-2015 01:25 AM
  4. Puzzlegal's Avatar
    Ouch, I use multiple phone numbers for several contacts. Maybe I'll need a third party contact app.
    07-26-2015 09:58 AM
  5. VooDooCC's Avatar
    I wish there was a way to set a "priority" number for each contact. Some I call home more, others work, others mobile.
    VZWsucks likes this.
    07-27-2015 09:11 AM
  6. VZWsucks's Avatar
    If you go into contacts and select a contact, press and hold the number of the contact you choose to be the priority number. A window will open, select default #. Now anytime you call or text that contact the default # will be used automatically.
    Sent from my DROID Turbo64 via Tapatalk
    VooDooCC likes this.
    07-29-2015 08:14 PM
  1. Contacts Issue
    By ihatevz1234 in forum Android 6.0 Marshmallow
    Last Post: 07-23-2015, 10:30 PM
  2. Why when I select a contact does the wrong contact comes up?
    By scissorino in forum Samsung Galaxy S6
    Last Post: 07-23-2015, 10:26 AM
  3. Replies: 0
    Last Post: 07-22-2015, 07:19 PM
  4. How do I sync my contacts and photos to my new phone?
    Last Post: 07-22-2015, 06:32 PM
  5. Replies: 0
    Last Post: 07-22-2015, 10:39 AM
