1. Gyrobob's Avatar
    I need to be able to silence the boot up noise.
    I know I can make it silent before shutting it off and then it won't make noise when it boots, but I need to be able to completely shut down the boot up noise. I need it to be silent even with the volume up. I want to either deselect the boot up noise, or swap the boot up sound file with a file that makes no noise.
    It seems the only way to got enough control to deselect that noise is to root the phone.
    So, how do I root the phone and then get into some file somewhere to shut off the boot up noise?
    Thanks
    07-27-2015 12:25 PM
  2. RJ_Butler's Avatar
    We don't have permanent root access as of yet. You can pay $20 to get "MofoRoot," but it's not the best solution. Check the XDA forums for more help
    07-27-2015 07:30 PM
  1. Replies: 8
    Last Post: 07-28-2015, 01:44 PM
  2. How do I send and receive group text with iPhones?
    Last Post: 07-27-2015, 01:15 PM
  3. How can I stop the double tap to unlock when making a call?
    Last Post: 07-27-2015, 12:16 PM
  4. How do you answer multimedia text messages?
    Last Post: 07-27-2015, 12:11 PM
