1. silverback's Avatar
    My Command Center widget has the spinning circle and won't load until a reset.
    Other widgets, like Starbucks, just don't work at all.
    Any ideas?
    08-01-2015 04:39 PM
  2. Ian Morgan2's Avatar
    Don't know much 'bout the specific widgets you refer to.....but wondered if they perhaps were dependant on Location being set ? Just a thought.
    08-01-2015 06:51 PM
  3. silverback's Avatar
    Well, the weather part of command center might, but the clock shouldn't. I am at a loss. I have to reset about once every other day.
    08-01-2015 07:23 PM
  4. Ian Morgan2's Avatar
    Seems like you should check the settings in the apps....i.e. Sky News requires background update setting interval to be set...for the app and the widget,
    Have you got them all enabled or perhaps background activity disabled ?
    08-01-2015 07:37 PM
  1. Replies: 1
    Last Post: 08-02-2015, 06:02 PM
  2. Why does my wifi and 3G keep turning on when the screen goes to sleep?
    By Omar Bentaleb in forum General Help and How To
    Last Post: 08-02-2015, 11:21 AM
  3. Replies: 1
    Last Post: 08-01-2015, 04:02 PM
  4. I cant keep app on my homepage
    Last Post: 08-01-2015, 03:53 PM
  5. Lte on my htc m8 doesnt work properly
    Last Post: 08-01-2015, 03:52 PM
