1. runduckrun's Avatar
    I had a Razr Maxx for a couple years and never had problems with my bluetooth in my car. I upgraded to a Motorola Droid Turbo in June. The bluetooth paired up with my car, no problem, and worked fine for about a week. Unfortunately, something happened and now the sound of the person I'm talking to is garbled, underwater, robotic...whatever you want to call it. I can hear them. The volume is fine. They can hear me fine with no problems. It's just that the incoming sound is messed up. I've taken it to my local dealership/mechanic and they tested it with multiple other phones (iphones, other androids like Samsung and such) and it works just fine. After all the troubleshooting, it really does appear to be something having to do with my particular phone.
    Does anyone know what might be causing this problem and how it might be fixed?
    08-05-2015 12:13 PM
  2. doogald's Avatar
    Do you have advanced calling turned on? If so, what happens of you turn it off temporarily? Does that make it better?
    If not, what happens if you turn wifi off before making a call. Does that help?
    08-05-2015 12:23 PM
  3. runduckrun's Avatar
    I have never activated Advanced Calling so I'm pretty sure that's not on. I'll have to try turning off wifi when I go to lunch today to see if that does anything. Hadn't thought of that yet.
    Any other possible troubleshooting ideas?
    08-05-2015 12:27 PM
  4. runduckrun's Avatar
    Well, I tried turning off my wifi connection and, sure enough, the bluetooth calls sound fine! Hopefully it really was that simple and it remains okay.
    Thanks for the suggestion!
    Viswanathan N likes this.
    08-05-2015 03:55 PM
  1. Where could my sound profile widget have gone?
    By WexIan in forum HTC One M9
    Last Post: 07-18-2016, 11:25 PM
  2. Replies: 2
    Last Post: 02-04-2016, 01:41 PM
  3. How can I fix r 3triangles with ? marks inside &?
    Last Post: 08-05-2015, 12:10 PM
  4. No sound when screen mirroring S3 to new Samsung smart TV
    By Rick Klugman in forum Ask a Question
    Last Post: 08-05-2015, 12:02 PM
  5. What is this whirring sound on my HTC One M8?
    By AC Question in forum HTC One M8
    Last Post: 08-05-2015, 10:56 AM
