1. milo williamson's Avatar
    Is there a very quick way how to drain the battery down to nothing?
    08-05-2015 06:48 PM
  2. russel5150's Avatar
    Not anything thats a quick drain that i know of, other than just doing some super big download.
    May i ask why you want to do that since draining it to zero is not recommended?
    08-05-2015 06:59 PM
  3. milo williamson's Avatar
    Want to try out an experament on it.
    08-05-2015 07:08 PM
  4. doogald's Avatar
    It's ok to do once in a while.
    08-05-2015 07:20 PM
  5. milo williamson's Avatar
    I am just doing this once, i will take a screen shot when its down to 3%
    08-05-2015 07:25 PM
  6. NoahForeman's Avatar
    Just stream Netflix or hulu with the screen on full brightness and all radios on. Navigate somewhere in the background as well in maps.
    VooDooCC likes this.
    08-08-2015 06:14 AM
  7. KillerQ's Avatar
    There are apps in the Play Store specifically for this purpose. They will maximize brightness, turn the flash on, and run intensive CPU cycles that will drain the battery very fast - just search for them.
    08-09-2015 10:07 PM
  8. russel5150's Avatar
    I am curious as to why..... I really want to know
    08-10-2015 02:24 AM
  9. milo williamson's Avatar
    Sorry been away for a long time on here, been really sick... oh just testing a thing about how long will down to at least fifteen percentage, can really make my phone hyper boost all the way up to full percentage.
    11-09-2015 07:46 AM
  10. rudytoots's Avatar
    There's one app that I used and it worked like a charm, got me from 80 to 5 in no joke 15 seconds. I don't have enough posts so I can't post links but it was called
    Just looked on the google play store, they deleted it I guess... Sorry man
    11-09-2015 05:23 PM
  11. matt.eskes's Avatar
    The device shuts off at 3% so have fun.
    11-10-2015 10:20 AM
  1. Replies: 20
    Last Post: 01-09-2016, 06:55 AM
  2. Replies: 6
    Last Post: 08-13-2015, 01:40 PM
  3. Replies: 2
    Last Post: 08-06-2015, 12:28 AM
  4. Replies: 1
    Last Post: 08-05-2015, 07:26 PM
  5. Replies: 0
    Last Post: 08-05-2015, 05:50 PM
