How's this for lollipop battery?
conan1071
269
17 hours off charger
3 hours 11 minutes talk
3 hours 45 minutes screen time
27% left
Would I get better on kit kat?
.asking because I'm within my 14 days and I know the store has 64gb ballistic nylon turbos on kit kat
mobrules
1,170
Here's mine on KitKat. It was over the weekend so low usage. But yes I do feel KitKat had a lower battery usage. Somewhere there are screenshots where I've gone 60 + hrs. It was in a thread about battery life. Your usage is good for LP, I just don't feel it's good enough for me.
conan1071
269
I did it. Went back to the store and got a turbo with kit kat on it. We'll see how the battery life is. So far, the lte signal is worse than previous turbo.
pdaniel219
208
My battery is way worse in lollipop. I'm at 15% right now with less than 3 hours screen on time. I used to get a consistent 5 hours SOT with kit kat. And my screen used to always be the #1 battery drain. Now it's cell standby and then android OS with screen in 3rd place. I've wiped cache and even done a FDR. I still love the phone. Wouldn't hesitate to grab the next generation of it. Just wish my battery were a little better.
mobrules
1,170
Good for you. Be sure you disable the apps from the pictures I posted. Hopefully that helps.
mobrules
1,170
Conan here ya go. I cleared cache after disabling all these. Some you may want. Don't use the moto screen stuff. Here is a screen shot of my battery before bed last night too.
mobrules
1,170
And I make no promises this will work and stop the update. All I know is so far it has for me and it doesn't prompt me anymore to do it. LP is great for some and a disaster for others. For me it destroyed my battery life but that's because of a weak 4g signal area.
smokie11
94
3
I believe KK is better, with about 28 hours off charger I get about 5-6 hours of screen time with all my junk running about 10% left.
dmoss84
6
I did a factory reset yesterday after noticing that Google play services and Android OS were taking the majority of my battery usage. The issue seems to have been fixed with the reset. This was the first factory reset since buying the turbo in October.
ParkerAdams
