1. gmags112's Avatar
    I tried searching for this with no definitive answer, but I am wondering if my phone is stuck while in this process or not. It has been in this state for 1.5 hours now. Here is what it is saying...
    qe 0/0
    -- Wiping cache...
    Formatting /cache...
    Is this what I am supposed to be seeing? Should it take over an hour to complete? It has never taken me this long before. Also, if it is frozen, how can I back out of it?
    08-19-2015 02:20 PM
  2. Crashdamage's Avatar
    I'm not sure what you can do other than just try rebooting the phone. If an ordinary power off/'power on reboot doesn't work you might try holding Power and Volume Up down together and see if you get a reboot or a menu.
    Clearing caches, particularly the cache partition, has become the Hot New Thing To Do lately. Not long ago you almolst never heard of it and that was a Good Thing. And while it shouldn't cause any problems, it's actually not a trivial operation that's totally without risk. Things can go wrong.
    So do not clear caches unless you have a specific problem that is cache-related. Cache files are there to speed up operation and best performance is achieved by leaving them alone to do their job. Clearing caches does nothing to increase performance in the vast majority of instances. If anything, it decreases performance, wasting CPU cycles and power rebuilding caches.
    08-19-2015 03:51 PM
  3. 1Coopgt's Avatar
    It takes my phone 20 minutes when I clear the cache . And yes that is what mine says when its running .
    08-19-2015 06:11 PM
  4. EricandSuebee's Avatar
    The only time I do a clear cache is on a big upgrade like 4.4.4 to 5.1 and will do so again when 5.1 to 6.0 happens. But that involves do a full data reset as well don't do them on small updates don't do the cache clears.
    Crashdamage likes this.
    08-19-2015 06:21 PM
  5. BiRONIC's Avatar
    qe 0/0
    -- Wiping cache...
    So, did yours ever stop the cache wiping process (on its own), or did you have to force it somehow (or wait for battery to die)?
    I'm having this right now; it's been a couple hours.
    04-19-2016 04:38 PM
  1. How can I get contacts from a Galaxy S4 with a bad LCD?
    By leickman in forum Samsung Galaxy S4
    Last Post: 08-19-2015, 09:51 PM
  2. Note 5 haptic vibrations with music playing
    By eclectic11 in forum Samsung Galaxy Note 5
    Last Post: 08-19-2015, 07:13 PM
  3. Can I get some help with data roaming S7 Edge issues?
    By kryshnakishore in forum General Help and How To
    Last Post: 08-19-2015, 01:21 PM
  4. Replies: 0
    Last Post: 08-19-2015, 01:15 PM
  5. Can I get some help with downloaded files?
    By lbabus in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 08-19-2015, 12:33 PM
