1. flybub's Avatar
    Hey all. Ever since LP this lag/stutter/hitch when swiping away apps in the recents menu is driving me crazy!!! Has anyone come across a fix or patch for this? I've restarted and cleared cache but nothing has worked. I do not want to do a Factory Reset unless it's my last option. Any suggestions?
    08-29-2015 09:16 AM
  2. PapaGary's Avatar
    A factory reset will not solve this problem. This is also my biggest gripe about Lollipop.
    08-29-2015 09:26 AM
  3. leehardballer12's Avatar
    There is a lag/stutter/hitch when swiping away recent apps?
    08-29-2015 06:48 PM
  4. EricandSuebee's Avatar
    I've not experienced this at all on my Turbo. But I also once I updated to LP, I cleared cache and did data reset to factory.
    08-29-2015 10:39 PM
  5. kmf1's Avatar
    Some have said that swiping away the Recent apps is not necessary, but like many since the Lollipop update, there is just something about wanting to do it. Literally hundreds of cards could build up and it just doesn't seem right. My wife's Verizon Galaxy S6 has a "Close all" button to close all the cards. We don't have that choice with our Turbos.
    08-30-2015 08:24 AM
  6. flybub's Avatar
    I don't know that it's necessary but, like kmf1 said, a boatload of cards build up in there. I've let it go before and never noticed any hiccup any where else while going through my normal tasks. I use my phone a bunch during the course of the day for work and I use different apps depending on what is going on so I do get quite the build up. Was just curious if anyone had dug deeper in finding a fix. Some nexus 6 users have reported it as well, oh well.
    08-30-2015 10:09 AM
  7. Johnny Fever's Avatar
    That lag sounds annoying. It happend to a tablet I updated to 5.0 and was annoying. I thought it had to do with bigger cards etc...Im still on fence re update to 5.0
    10-23-2015 05:50 PM
  8. CharlieL3's Avatar
    Any fix for lag on swiping away recent apps?
    Yes.
    Don't swipe away the apps.
    hub1 likes this.
    10-23-2015 05:56 PM
  9. Johnny Fever's Avatar
    if u dont swipe them doesnt that utilize some ram or something?
    10-23-2015 07:03 PM
  10. doogald's Avatar
    Not really (or not in an important way). The OS manages the RAM nicely. It's ok to swipe away an app that is draining battery (because it's a crappy app). But RAM that is not being used doesn't help you at all. Linux manages RAM very differently from Windows.
    Even apps that aren't running show in the list - it's just a list of your last used apps (and browser tabs) in the order you've used them.
    10-23-2015 07:53 PM
  1. Replies: 1
    Last Post: 08-29-2015, 10:01 AM
  2. Why do my apps keep crashing?
    By WildHog96 in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-29-2015, 09:05 AM
  3. Replies: 0
    Last Post: 08-29-2015, 08:44 AM
  4. Why don't my multi window have an arrow tab on the home screen?
    Last Post: 08-29-2015, 07:25 AM
  5. how can i fix privacy protection password in my phone?
    Last Post: 08-29-2015, 07:12 AM
