1. AC Question's Avatar
    I do not want the phone to ring when telemarketers call
    09-04-2015 10:21 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! That would require the phone to know that it's a telemarketer, which can be difficult. Even if you know of a number that is a telemarketer, they usually use many different numbers to call, so blocking one won't block the telemarketer for good.
    09-04-2015 02:49 PM
  3. doogald's Avatar
    After they call the first time, create a contact for the phone number (or add it to an existing contact called "telemarketers" or something). Then open the contact in the people app, hit the menu, and set the ringtone for the contact to nothing, or have it send directly to voicemail.
    09-04-2015 03:25 PM
  4. GeodudeFFP's Avatar
    Maybe I'm missing something here, but...get a call blocker app - one that recognizes telemarketing numbers. There's quite a few in the app store.
    09-05-2015 04:18 AM
  5. B. Diddy's Avatar
    I'm curious--how good are those apps at recognizing telemarketer numbers? A single telemarketer or robocaller will often use a whole variety of phone numbers to call from, so if you block one of them, they'll get you with another number.
    09-05-2015 08:45 PM
  6. GeodudeFFP's Avatar
    I've had great luck with them...can't remember the last time I've had to answer a telemarketing call.
    09-05-2015 09:24 PM
  1. Replies: 5
    Last Post: 03-17-2016, 09:03 PM
  2. Replies: 10
    Last Post: 10-14-2015, 01:29 PM
  3. How to Mirror S4 to HDTV?
    By pailisjano30 in forum Ask a Question
    Last Post: 09-04-2015, 02:55 PM
  4. NonAllowed Item
    By StayFly in forum Marketplace Archive
    Last Post: 09-04-2015, 10:33 AM
  5. Replies: 1
    Last Post: 09-04-2015, 10:06 AM
