1. AC Question's Avatar
    I can't open the sim card drawer on the droid turbo
    09-04-2015 05:48 PM
  2. Rukbat's Avatar
    I don't have one, so this is just a wild guess, but look for a little hole next to the drawer. You should have gotten a tool that's an oval of wire with a piece of wire sticking straight out of one of the short curves. Stick that piece into the hole and press gently. Wither the drawer wqill pop out, or as you press, the drawer will slide out.
    09-04-2015 07:10 PM
  3. KSDroid01's Avatar
    The sim card tray in the Turbo is a bit different than most other phones; it's integrated into the volume rocker. You can pull it out by using your fingernail on the bottom of the volume rocker.
    Posted via Moto Turbo
    09-06-2015 01:18 AM
  4. GeodudeFFP's Avatar
    This. And for any other general questions, check this: http://dl4.htc.com/web_materials/Man...User_Guide.pdf
    09-06-2015 02:54 AM
  5. 1Coopgt's Avatar
    Why would we use the HTC M9 user guide for the Motorola Turbo ? Seems to me the OP should reference the Moto Turbo user manual don't you think ?
    09-06-2015 09:46 AM
  6. GeodudeFFP's Avatar
    Good point! This is the link I meant to post:
    http://www.cellcom.com/resources/med...xUserGuide.pdf
    09-06-2015 05:13 PM
  1. How do I turn on the in-call status popup on my Note 5
    By PoopooHead69 in forum Samsung Galaxy Note 5
    Last Post: 05-05-2016, 08:01 PM
  2. How to retrieve a deleted voice mail message?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 09-13-2015, 09:01 AM
  3. Storage on Samsung Galaxy Note 4?
    By johnlance in forum Samsung Galaxy Note 4
    Last Post: 09-09-2015, 11:54 AM
  4. How do you play videos continuously?
    Last Post: 09-06-2015, 07:55 PM
  5. Why won't my Droid Maxx stay connected to wifi?
    By AC Question in forum Motorola Droid MAXX
    Last Post: 09-04-2015, 05:18 PM
