1. this_is_nascar's Avatar
    Over the last couple months, battery life has shortened quite dramatically. I don't understand how to interpret these stats, however, why is WiFi showing this when I've had a mix of times when I had WiFi on and off?
    Thanks.
    Sent from my XT1254 using Tapatalk
    09-12-2015 03:12 PM
  2. this_is_nascar's Avatar
    Anyone? Please.
    09-13-2015 02:25 PM
  3. this_is_nascar's Avatar
    Pretty please? I could really use some help here folks, in addition to learning how to find out what's keeping the phone awake, as shown above. I'd really appreciate the help and/or advice. I'm not rooted.
    09-14-2015 05:45 PM
  4. doogald's Avatar
    In advanced wifi settings there is a setting scanning always available, which keeps the wifi radio on for location services even when you switch it off. Could be that?
    Cell standby being high would be more worrying. There are times have bad signal.
    Anyway, you're trending to go through a full day easily. That's pretty much all I need from my phone. I plug in while I sleep anyway.
    09-14-2015 08:49 PM
  5. Toes Up's Avatar
    The Google Play Services usage seems a little high too. You might want to try and "force stop" that app.
    09-14-2015 09:13 PM
  6. this_is_nascar's Avatar
    Thanks. I appreciate it. What about all the awake time? Anyway to find out what that is, without being rooted?
    09-15-2015 04:21 AM
  7. doogald's Avatar
    Force stop Google Play services? I don't think so...
    Awake time are apps getting updates in the background. What are the two apps with icons in the status bar in your photos? One has the date, the other is a square with a bunch of stuff inside. Maybe it's one of those?
    Do you have a weather app or widget that gets updated periodically? Facebook, Instagram, twitter? Do you have an email app that updates on a schedule? Any phone calls? That would explain the awake time (which doesn't look too bad in that graph.)
    09-15-2015 05:35 AM
  8. Toes Up's Avatar
    Perhaps I was thinking of the Google Play Store which was a bit of a battery hog for me in the past. My apologies.
    09-15-2015 10:04 AM
  9. this_is_nascar's Avatar
    I gotcha. It's probably those background apps, as you mentioned. I get email and weather updates hourly.
    09-16-2015 09:24 AM
  1. How do I fully root a Motorola Droid Maxx with Android 4.4.4?
    By AC Question in forum Motorola Droid MAXX
    Last Post: 02-14-2017, 10:02 PM
  2. Galaxy S6 Edge Battery Life
    By datgoldmember in forum Samsung Galaxy S6 edge+
    Last Post: 11-04-2015, 11:24 AM
  3. How much storage needed?
    By Mooncatt in forum HTC One M8
    Last Post: 09-14-2015, 02:38 PM
  4. note 5 battery
    By Aya Kamal in forum Samsung Galaxy Note 5
    Last Post: 09-12-2015, 01:32 PM
