Save big + get 3 months free! Sign up for ExpressVPN today
  1. Dakotabaker98's Avatar
    Ok, so my Droid "Turbo" doesnt even last me a day. I have had the phone for about 10-12 months now and well the battery is crap. I have to charge multiple times through out the day or it just wont last me at all. Ill include all the possible screen shots yall could need to inform me of what could be going on! Also, is anyone else still having the issue of the phone using data while connected to wifi? i some how manage to use around 22GB of data in about 10 days. my bill is almost 600$ a month for the past 3 months. Cant figure out my issue. Thanks for any info and input!
    Attached Thumbnails My Battery Has To Be Bad!!!!-screenshot_2015-09-21-18-17-45.jpg   My Battery Has To Be Bad!!!!-screenshot_2015-09-21-18-17-48.jpg   My Battery Has To Be Bad!!!!-screenshot_2015-09-21-18-17-53.jpg   My Battery Has To Be Bad!!!!-screenshot_2015-09-21-18-21-26.jpg   My Battery Has To Be Bad!!!!-screenshot_2015-09-21-18-21-47.jpg
    09-21-2015 06:29 PM
  2. JJ Jones's Avatar
    I'm betting it's that Casper app, not only because of the high numbers it shows in your battery stats, but since it's not even available on the play store, I'd call it a little sketchy.
    It's likely what's burning up your data too. Maybe some less than reputable stuff going on behind the scenes.
    09-21-2015 06:44 PM
  3. 1Coopgt's Avatar
    Couldn't be the Casper overlay for Twitter could it ?
    09-21-2015 06:45 PM
  4. Dakotabaker98's Avatar
    ill unintal the casper app for a few days and see what happens. didnt think of that!
    09-21-2015 06:54 PM
  5. Eclipse2K's Avatar
    I'm also betting that it's the Casper app. Let us know.
    09-21-2015 07:33 PM
  6. jrmt077's Avatar
    To keep your phone from using data while on WIFI, Go into settings / WIFI / advanced/ and uncheck avoid bad WIFI connections. This will keep your phone from turning on data when WIFI signal is sketchy. I had a similar prob when I first got phone, using 4G when on WIFI. Good luck.
    09-22-2015 07:54 AM
  1. Replies: 2
    Last Post: 09-23-2015, 07:07 PM
  2. My Nexus 7 2013 will no longer accept a charge. Any help?
    Last Post: 09-22-2015, 03:39 AM
  3. Why can't I root my Note 2?
    By AC Question in forum Samsung Galaxy Note 2
    Last Post: 09-21-2015, 06:25 PM
  4. Replies: 0
    Last Post: 09-21-2015, 06:18 PM
  5. Verizon VZWAVS servicer has stopped
    Last Post: 09-21-2015, 06:05 PM
