1. edison2012's Avatar
    Okay, I'll try here in this subforum. I just noticed that with the Lollipop upgrade "most" of my status bar icons are now white. My only issue is with GoSMS Pro. I had it configured to display different color icons for txt msgs from different individuals. It made it easy to tell if it was from a primary person (wife, friends, etc). I've gone through all the GoSMS menus, but I can't get the functionality I once had.
    I know it possible to change colors because my AVG antivirus app displays in color in the status bar.
    edison
    09-24-2015 08:30 AM
  2. edison2012's Avatar
    Just found the developer's FB page and they are aware of the problem. Doesn't look like a fix yet.
    edison
    09-24-2015 10:27 AM
  1. Moto X and a failing battery.
    By psimon1210 in forum Moto X (2013)
    Last Post: 02-19-2017, 10:52 AM
  2. Replies: 3
    Last Post: 10-01-2015, 01:08 AM
  3. Transfering and converting sms to text doc.
    By orangesims in forum LG Optimus L
    Last Post: 09-26-2015, 12:51 AM
  4. Replies: 0
    Last Post: 09-24-2015, 07:00 AM
  5. Replies: 1
