1. Never-Enough's Avatar
    Whenever I take a video w/my Droid Turbo the audio always sounds muffled. Is there a fix for this or are we just stuck with this **** phone?
    09-28-2015 09:42 PM
  2. Zachary Boddy's Avatar
    Could be you got some muck in your mic. Worth a check. I'm not sure where it is on the Droid Turbo, honestly. Or if there's more than one (high end Lumias for example have four for HAAC).
    09-28-2015 09:44 PM
  3. Never-Enough's Avatar
    Always been like this, no muck anywhere.
    09-28-2015 09:45 PM
  4. Zachary Boddy's Avatar
    It could honestly just be the phone. It could be poor placement (you might be covering it), a case you might be using, a defect in the phone, or simply poor hardware. Or a combination of all at once. Process of elimination should give you the answer. Make sure how you hold the phone would cover the mic at all, try it without a case (if you use one), and do some research to see if the problem is common.
    09-28-2015 09:49 PM
  5. Zachary Boddy's Avatar
    Is your name a reference to the Five Finger Death Punch song or am I being really obscure?
    09-28-2015 09:50 PM
  6. Never-Enough's Avatar
    Never had a case & I have tried holding it all over. Same problem. My username is not a reference to 5FDP.
    09-28-2015 09:55 PM
  7. Zachary Boddy's Avatar
    I haven't heard of any muffled audio issues with the Droid Turbo (although I don't pretend to constantly ferret out the latest Droid Turbo news so I may be wrong) so I'd try consulting Motorola and see if it's a defect that you can get fixed or replaced.
    09-28-2015 10:00 PM
  1. Sounds and notification
    By Marioclement23 in forum Samsung Galaxy S5
    Last Post: 09-28-2015, 05:50 PM
  2. Replies: 1
    Last Post: 09-28-2015, 05:32 PM
  3. Galaxy S4 - caller getting "modem" sound & I can't here them
    Last Post: 09-28-2015, 02:33 PM
  4. My snap videos always glitch
    By Mzlularh in forum Ask a Question
    Last Post: 09-28-2015, 11:11 AM
  5. Why can I play videos but no sound on my Droid Maxx?
    By AC Question in forum Motorola Droid MAXX
    Last Post: 09-28-2015, 09:48 AM
