1. ascene's Avatar
    For the past few weeks, the WiFi on my Droid Turbo will just drop out of no where. Usually, every ten to fifteen minutes, give or take.
    Now this is what confuses me, well two things:
    1. I will swipe down to check if I'm connected to WiFi and sometimes will see a "0x" where it should say "Netgear."
    I'm always on the WiFi at home. I've been yelled at enough times to know not to use the shared data plan when there's WiFi.
    2.
    No Saved Networks Avaliable.
    Same picture it says directly underneath "Connected to Netgear."
    Granted, I took the 2nd screenshot nanoseconds after the first, but it will say "No Saved Networks Avaliable" until I go into the Wifi settings either wait a few seconds or connect to the network manually.
    We just upgraded the bandwidth. At first, alright, every now and then it would drop.
    But now it's completely giving up and it's annoying.
    Please help :[
    10-03-2015 06:40 AM
  2. Eclipse2K's Avatar
    Is it possible you need to factory reset your router? It seems as if the router randomly fails to send out a signal. Does the phone find the router if you reboot the router or even the phone? Which one?
    You provided great information but there is more needed. Also, make sure Avoid Poor WiFi Connections is disabled. It's under WIFi Advanced Settings. I check marked it so you know what I'm referring to.
    maxman1 likes this.
    10-04-2015 04:41 AM
  3. maxman1's Avatar
    Every similar case I've seen personally has proven to be an issue with the router except one that was a modem starting to fail. I'd check for a firmware update and if not available, at least reboot modem & router.
    10-04-2015 04:14 PM
  1. Screen timeout issue
    By Tahir Ahmed1 in forum Samsung Galaxy Note 4
    Last Post: 10-03-2015, 06:53 AM
  2. Why does wifi only work sometimes?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 10-03-2015, 06:14 AM
  3. Problems with WiFi connection
    By eddie Sim in forum Samsung Galaxy Tab S 8.4
    Last Post: 10-03-2015, 04:08 AM
  4. Replies: 1
    Last Post: 10-02-2015, 11:47 PM
  5. Lollipop issues
    By 88dale88jrfan in forum Android 5.0 Lollipop
    Last Post: 10-02-2015, 09:17 PM
