1. Johnny Fever's Avatar
    Hello,
    Basically, occasionally I am having issues where callers cant hear me. Seems to be increasing and if I power off the phone it works again. I think its somehow related to bluetooth but havent pinned it down yet.
    I have rec'd conflicting info from Verizon. One rep says factory reset then do 5.0. But then I talked to another that states I should update to 5.0 and then do reset...Any other input out there?
    Been holding off on 5.0 b/c bricked a tablet but from what I have read things seem to be received well so far...
    JF
    10-23-2015 01:00 PM
  2. jesta192's Avatar
    I've been running 5.1 since the soak test, and it works fine for me.
    Upgrading may resolve the problem, which would mean you might not have to try the factory reset. I am aware that some people do a factory reset after every upgrade out of habit, however, so you'll have to make that call.
    maxman1 likes this.
    10-23-2015 01:18 PM
  3. doogald's Avatar
    I'd factory reset after the update if it was me, but it won't hurt (and will make the update go faster) if you reset before, too. Just do the reset again after. But, if you only want to do it once, do it after.
    10-23-2015 01:33 PM
  4. Johnny Fever's Avatar
    Thanks...will likely reset after update to 5.0.
    Just did a clear cache partition and my 5.0 that was waiting got blasted. Will download again...
    10-23-2015 04:42 PM
  1. Samsung S5 5.1.1 Update download?
    Last Post: 11-16-2015, 11:52 AM
  2. Cheapest way to buy Gear S2
    By vlfifthdawnlv in forum Samsung Gear S2
    Last Post: 10-25-2015, 12:21 PM
  3. Replies: 1
    Last Post: 10-23-2015, 02:42 PM
  4. moving all contacts and pictures from old phone to new phone.
    Last Post: 10-23-2015, 01:57 PM
  5. Replies: 0
    Last Post: 10-23-2015, 12:34 PM
