1. dturbo80's Avatar
    It seems like this phone can use a lot of data, sometimes even while on wifi. an example of an app that does this is TuneIn Radio. Thanks.
    10-24-2015 04:54 PM
  2. Einsteindks's Avatar
    At least on Wi-Fi, you're not on the plan. Verizon has opted not to activate the FM chip in our phones as yet, so any music you hear, you are streaming over the Internet or your data plan.
    10-24-2015 06:21 PM
  3. jrmt077's Avatar
    Go to advanced wifi settings and uncheck avoid bad wifi signals. This is on by default and uses 4G when wifi signal is not strong.
    10-26-2015 10:41 AM
  4. madroxide's Avatar
    I went into each app and set the disable background data option. It has saved me much data.
    10-26-2015 07:43 PM
  5. dturbo80's Avatar
    How do you do this?
    10-27-2015 11:57 AM
  6. beeztrain's Avatar
    How?
    11-03-2015 09:57 AM
  1. Replies: 0
    Last Post: 10-24-2015, 04:04 PM
  2. So i locked my galaxy note 4 with a pin lock
    Last Post: 10-24-2015, 03:33 PM
  3. Why is so slow to catch wifi signal ??
    Last Post: 10-24-2015, 02:50 PM
  4. WiFi network only discovered on phone reboot
    By Senninte in forum Ask a Question
    Last Post: 10-24-2015, 02:34 PM
  5. Why is the keyboard not coming up on my smartphone?
    Last Post: 10-24-2015, 02:23 PM
