1. bigbadwulff's Avatar
    How do I disable it on the Turbo? All my other phones had an easy way to do it. Can't find it on the Turbo settings.
    10-27-2015 11:04 PM
  2. doogald's Avatar
    I don't think that there are too many settings on the stock launcher, but you can install a replacement like Nova Launcher or Action Launcher that has an option not to scroll wallpaper.
    10-28-2015 06:17 AM
  3. russel5150's Avatar
    Download quickpic app. You can set a pic as wallpaper and it will let you choose the portrait mode (doesn't move) or wide mode which moves.
    Its a simple fix that doesn't require any launchers. The quickpic app is actually a good and simple app to use as a photo gallery, Ive used it the last few years.
    Btw, i cant stand a moving background!!
    Sent with my white Note5 with nonremovable back and no SDcard!
    10-28-2015 06:20 AM
  4. bigbadwulff's Avatar
    Thanks
    10-29-2015 12:45 AM
  1. (-HD-) Wallpapers
    By RussianSolja in forum Blu Android Phones
    Last Post: 02-12-2016, 03:19 AM
  2. [APP][4.0+]NRG Beams Live Wallpaper
    By MunkeeBonez in forum Wallpapers, Ringtones, and Themes
    Last Post: 12-30-2015, 05:41 AM
  3. [APP][3.0+]Color Puddle Live Wallpaper
    Last Post: 11-25-2015, 05:11 AM
  4. Replies: 1
    Last Post: 10-30-2015, 04:38 AM
  5. Replies: 0
    Last Post: 10-27-2015, 02:34 AM
