S StutterStep Active member Nov 21, 2013 35 0 0 Visit site Nov 19, 2015 #1 *#*#4636#*#* doesn't work in the dialer like other moto phones I've tried. How do I get this to work? I just want my phone to stay on WCDMA only Posted via the Android Central App
S StutterStep Active member Nov 21, 2013 35 0 0 Visit site Nov 19, 2015 #3 Nothing happens Posted via the Android Central App
D doogald Trusted Member Jan 3, 2010 4,425 55 0 Visit site Nov 19, 2015 #4 You can go into the settings, find mobile data, and switch "Preferred Network Type" from Global or CDMA/LTE to LTE/GSM/UMTS. You don't need a dialer test menu.
S StutterStep Active member Nov 21, 2013 35 0 0 Visit site Nov 20, 2015 #5 But I want to force 3G only
D doogald Trusted Member Jan 3, 2010 4,425 55 0 Visit site Nov 20, 2015 #6 Well, you didn't say that. This app works for that on the Droid Maxx. Should work on the Turbo. https://forums.androidcentral.com/e...etails?id=net.andirc.lteonfoff&token=G5LZBeTB Read the instructions that pop up carefully to see which setting you should change to. You'll have to run it again every time you restart the phone if it's like the Droid Maxx.
1Coopgt Well-known member Apr 9, 2014 641 61 28 Visit site Nov 21, 2015 #8 Wouldn't have been cheaper to buy a flip phone?
S StutterStep Active member Nov 21, 2013 35 0 0 Visit site Nov 25, 2015 #9 lol not everybody needs like 40Mbps download plus I get better battery life
P PeterTheGeek Active member Jan 9, 2015 39 0 0 Visit site Nov 25, 2015 #10 There is an app called phone info.
P PeterTheGeek Active member Jan 9, 2015 39 0 0 Visit site Nov 25, 2015 #11 There is this app called phone info. And theres more detailed settings. Attachments 1448464462660.jpg 80.3 KB · Views: 8 1448464481881.jpg 58.4 KB · Views: 8
D doogald Trusted Member Jan 3, 2010 4,425 55 0 Visit site Nov 25, 2015 #12 Yep, that looks the same as the one I linked above.
