1. Shadowwoodrn1's Avatar
    Does anyone know of a micro usb to RCA converter that works for the Droid Turbo?
    11-26-2015 09:58 AM
  2. Einsteindks's Avatar
    As best I know, the Turbo simply does not put any video (and maybe audio as well) signal out through the USB port. Only option is wirelessly
    Shadowwoodrn1 likes this.
    11-26-2015 10:21 AM
  3. madaudio's Avatar
    Don't know the Droid Turbo specifically, but many many android phones and tablets will play audio out through their usb port via an "On-the-Go" usb cable. Not any old usb cable that physically plugs into your device, cable must be labelled as an "on-the-go". Your device must also be able to use on-the-go. You will then need some sort of DAC to connect to the phone, plus an app on your device that will utilise your device's ability to send music out through the on-the-go cable.
    Check out Enable USB audio on any Android 4.0 smartphone/tablet - AVS Forum | Home Theater Discussions And Reviews
    As for video you need to buy what is called an MHL cable that has a plug on one end that fits your phone's usb port, and it has an HDMI socket on the other end which you can then hook up to your tv or, if you have one, you av receiver. Google MHL.
    12-04-2015 10:12 AM
  1. Should I switch back to Verizon??
    By angelbones1 in forum Google Project Fi
    Last Post: 12-01-2015, 11:12 PM
  2. How do I shut off a beep in Google voice?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 12-01-2015, 04:41 AM
  3. How do I remove grayware from an Android phone?
    By AC Question in forum Displays
    Last Post: 12-01-2015, 04:39 AM
  4. Replies: 2
    Last Post: 11-27-2015, 09:09 AM
  5. Problem adding ringtone to contacts
    By Alan FL in forum Samsung Galaxy Note 5
    Last Post: 11-26-2015, 09:54 AM
