1. GWHeretic's Avatar
    I seem to have a dead spot on my screen, in the upper left hand corner. This would be for instance; the left hand side of the Google search bar, the Inbox drop down menu in Gmail, the drop down menu spot for the NFL app, etc. Anybody else seen this. I've tried several re-boots but it remains the same. Also tried lifting the screen protector and had no luck.
    It's a Motorola Droid Turbo ballistic nylon 64gb.
    Thanks, Rich.
    11-29-2015 10:31 AM
  2. HowardShap's Avatar
    I can't post a link yet, but Google dead pixels as there are some remedies for stuck pixels online that may help you.
    11-29-2015 11:31 AM
  3. PSPVinyls's Avatar
    Bumping this because I would like to get an opinion from anyone on what would be the best app to use. Googling it showed me the Dead Pixel Detect And Fix app. Is that a good one to use?
    02-15-2016 02:11 AM
  4. doogald's Avatar
    Dead spot upper left corner? Do you also have the Facebook Messenger app installed? If yes, when you go into settings, do you have the chat heads feature turned on? If yes to both, does turning off chat heads fix the problem?
    02-15-2016 05:42 AM
  5. PSPVinyls's Avatar
    oops!
    Yeah it's the left side XD
    was looking at my phone too early in the morning
    I'll try your instructions soon and let you know. Thanks!
    02-15-2016 10:04 AM
  1. S6 skips tracks when locking screen
    By utterbutter in forum Samsung Galaxy S6
    Last Post: 11-30-2015, 03:51 AM
  2. How to display Contact On Phone ?
    By Tajinder Singh5 in forum Android 5.0 Lollipop
    Last Post: 11-29-2015, 10:10 AM
  3. I have problems by logging in on instagram, how can I fix that?
    Last Post: 11-29-2015, 09:57 AM
  4. Cyanogenmod on an unlocked P607T?
    By J-Peg in forum Samsung Galaxy Note 10.1 Rooting, ROMs, & Hacks
    Last Post: 11-29-2015, 09:56 AM
  5. Replies: 0
    Last Post: 11-29-2015, 09:55 AM
