1. gemery#CB's Avatar
    So looking at swapping to the Verizon messaging plus app, it seems to do some things that I am looking for.. Two questions
    Am I able to adjust the alert tone per user that sends me a message
    Am I able to adjust the Notification icon that shows in the top bar of the phone per user (different Color per sender)
    Thanks in advance
    12-07-2015 02:56 PM
  2. MNSnowman's Avatar
    No and no, I fear. At least I've not found a way.
    12-07-2015 07:03 PM
  3. berserker's Avatar
    You can create alert tones per user.
    Einsteindks likes this.
    12-07-2015 08:47 PM
  4. mrtonk's Avatar
    Doesn't it use data for messages somehow instead of straight SMS?
    12-07-2015 11:48 PM
  5. gemery#CB's Avatar
    Thought I read that it uses wifi for text messages, was not sure about the data part.. But that would be of concern
    12-08-2015 08:04 AM
  6. JohnS305's Avatar
    You can customize the alert tone per user.
    It uses wifi when your connected to wifi, and regular the cellular network when not.
    It doesn't use data to send or receive messages, any data use is just typical background stuff like any app and very negligible.
    12-08-2015 10:42 AM
  7. D._Manley's Avatar
    And, how is this done?
    12-08-2015 02:30 PM
  8. JohnS305's Avatar
    Go into the conversation of the individual you want to change. Tap the three vertical dots in the upper right corner. The first option is customize, in there you'll see tones.
    12-08-2015 02:44 PM
  9. D._Manley's Avatar
    Are you sure that option does not change the default notification for all messages?
    12-08-2015 02:53 PM
  10. JohnS305's Avatar
    No if you go into the individual conversation it only changes. That person.
    12-08-2015 02:57 PM
  11. D._Manley's Avatar
    Thanks, I'll check it out. If accurate, the menu should be modified for a little clarity to differentiate the individual setting - as is, the option is identical to the universal setting.
    12-08-2015 03:09 PM
  12. PowrDroid's Avatar
    You have to have started a conversation with someone before you can make a custom alert tone for that person. So the first text you get from someone will be the default alert tone, then you can change it to a custom tone. Warning: If you delete a conversation with a person, you will have to assign the custom tone to them the next time you start a new conversation.
    So, in effect you are assigning custom alert tones to conversations.
    12-08-2015 04:56 PM
  13. D._Manley's Avatar
    Ah...
    Thanks again. Since I prefer a "neat" text app I empty it out when done with a conversation so, the feature is of no use to me. Still, good to know...I can see a few cases where it might be useful.
    12-08-2015 06:54 PM
  14. gemery#CB's Avatar
    All great answers....Thank you, will check it out
    12-09-2015 10:08 AM
  1. How to make text messages in order.
    Last Post: 12-14-2015, 04:03 AM
  2. Charger question
    By NYfan78 in forum OnePlus 2
    Last Post: 12-09-2015, 12:38 PM
  3. Replies: 1
    Last Post: 12-07-2015, 02:49 PM
  4. Text messages have no return(line of text)
    Last Post: 12-07-2015, 12:33 PM
  5. 3 days in with new 360. Wifi/bluetooth questions.
    By Nodnerb in forum Android Wear
    Last Post: 12-07-2015, 11:14 AM
