1. ejweber's Avatar
    I was recently sent a refurbished Turbo by Motorola to replace a device that was on the fritz. When I look at the storage screen in the settings menu, it shows 24.13 GB total space and 19.00 GB available. I can't remember what I used to see on my old Turbo. Is this what I should I expect to see?
    12-15-2015 07:11 PM
  2. Einsteindks's Avatar
    That looks like a 32 gigabyte turbo, but still a little low. Have you done a complete factory reset? Have you RSD it with the latest image? How big was the turbo that you traded in?
    12-15-2015 09:45 PM
  3. ejweber's Avatar
    Thanks for the reply! I just received the phone yesterday and it had not been set up prior. It IS a replacement for a 32 GB Turbo, so I assume it should have 32 GB as well. When I look in the settings menu on my wife's 16 GB Galaxy S5, it shows 16 GB of "total space," although there's obviously less usable space on the phone. This leads me to believe that my phone should show 32 GB of "total space," and not the 24 GB I see.
    I was hoping one of you that owns a 32 GB model could take a look in your own settings menu and share what you see there. It may be that this is common to all Turbo's. However, IF something is wrong with my internal memory, 8 GB seems to be a reasonable amount of memory to be missing.
    12-16-2015 11:24 AM
  4. Mikey D_PhD's Avatar
    The total space on my 32gb turbo is 23.63. Unlike some other devices, it doesn't show the space that the os takes, which is around 9gb. Mine has always shown this. My question is what is taking up that other 5gb from the 24 to 19. Have you already set the phone up? Have you considered a factory reset? Can you screenshot the memory page and post it?
    12-16-2015 02:09 PM
  5. Mikey D_PhD's Avatar
    Here's what mine looks like.
    12-16-2015 02:12 PM
  6. TiMar99's Avatar
    I'm showing 23.63 on my 32gb as well.
    12-16-2015 04:55 PM
  7. ejweber's Avatar
    Thanks again for the replies. I got the phone a couple of days ago, but I was quick to put a number of apps back on it (as well as allow it to download a number of podcast episodes). I think it's weird the way the Turbo reports "total space," but it looks like all is well here.
    12-16-2015 11:46 PM
  1. How can I fix my battery that has been hacked by a malware virus?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 03-19-2016, 06:47 PM
  2. How do I access the calculator on my LG3 phone?
    By AC Question in forum LG G3
    Last Post: 12-15-2015, 11:59 PM
  3. SPen alert - how does it work?
    By bertsirkin in forum Samsung Galaxy Note 5
    Last Post: 12-15-2015, 05:57 PM
  4. Replies: 1
    Last Post: 12-15-2015, 05:39 PM
  5. How do I change which pane is my home screen ?
    Last Post: 12-15-2015, 05:30 PM
