1. Jeff Harris's Avatar
    My old htc m8 had a box to check in settings so the volume and notifications sounds would be the same. is there a way to do this on the turbo? or just download an app?
    12-17-2015 02:15 PM
  2. Einsteindks's Avatar
    Your assumption is correct, as it is most likely a common Android system option
    12-18-2015 12:51 AM
  3. Bitterman's Avatar
    You can't lock the two settings together on the stock Turbo, you need to use an app. I do miss that feature but I have not bothered with a sound/volume app. I'm sure others can recommend some good ones. :-)
    12-18-2015 04:57 AM
  4. Jeff Harris's Avatar
    DANG.... that's one thing that sucks, I turn the volume down at home, but the text volume stays up loud, and scares the **** outta me when it goes off ! LOL
    12-22-2015 11:38 AM
  1. Why has Chrome lost sound for prime videos?
    By AC Question in forum Chrome
    Last Post: 05-18-2016, 03:54 AM
  2. How do I disable email notifications in Notification Panel?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 12-18-2015, 08:10 PM
  3. How to unlock my phone with broken volume key?
    Last Post: 12-17-2015, 12:37 PM
  4. Disable email notifications in Notification Panel
    Last Post: 12-17-2015, 11:56 AM
  5. Replies: 1
    Last Post: 12-17-2015, 09:45 AM
