1. flybub's Avatar
    Hey everyone. Before Lollipop I knew there was an issue where incoming calls would go straight to voicemail and there was no record of a missed call. It happened to me quite often and since Motorola and verizon kept pointing the finger at each other with no fix. I'm contemplating giving my turbo to my daughter but if the problem still persists I'm not going to. Can anyone verify this?
    12-23-2015 06:10 PM
  2. TiMar99's Avatar
    Swap out your Sim at a VZ store that solved my issue with missed calls. LP works great on the Turbo.
    12-23-2015 06:14 PM
  3. mrtonk's Avatar
    I've never had that issue. I am on LP.
    12-24-2015 12:00 PM
  4. anon(2978616)'s Avatar
    Never had this issue and I'm on LP.
    12-24-2015 01:27 PM
  5. flybub's Avatar
    Thanks for the replies. Apparently LP has fixed it if some of you are not having this issue. I put my SIM card from my turbo in my iPhone and it it's fine so I know it's not the SIM card. Thanks again for the replies.
    12-24-2015 02:39 PM
  1. Verizon Note Edge issues
    By JaiHook in forum Samsung Galaxy Note Edge
    Last Post: 02-08-2016, 11:34 AM
  2. How do I fix force closing of the Play Store on my LG Risio phone?
    By AC Question in forum LG Android Phones
    Last Post: 12-26-2015, 01:01 AM
  3. Replies: 2
    Last Post: 12-25-2015, 07:23 AM
  4. Why does a + sign keep on popping up before the phone numbers?
    Last Post: 12-23-2015, 05:41 PM
  5. How can I get app onto my Droid Turbo 2?
    By AC Question in forum Motorola Droid Turbo 2
    Last Post: 12-23-2015, 04:04 PM
