1. Geraldo Rocha's Avatar
    Hello!
    I'm really desperate for help!
    I recently screwed up with my micro USB cable and I don't have any other capable for Turbo charging
    This phone has a massive battery and needs a massive charger...
    so I'm here to ask for recommendations, the best cable to replace my broken one, if possible the one that comes with the device, I can only find the cable with the wall charger which I already own.
    Help. Thank You!!
    12-26-2015 04:12 PM
  2. parthtc09's Avatar
    You can use any micro USB cable that doesn't matter, now charger wise you need something Qualcomm 2.0 certified. If that's what you are looking for check amazon, just bought one for like 6.99.
    12-26-2015 05:15 PM
  3. Phoenix212's Avatar
    Not exactly true. Many older micro usb cables won't charge at Quick Charge 2.0 speeds. I recommend Anker brand cables. Personally, I like the nylon braided cables for their durability and look. A six foot Anker nylon braided cable (red) is going for $5 on Amazon right now with free shipping (no Prime needed). I purchased this same cable and it works perfectly.
    Any Anker cable will work with QC2.0. Aukey is another good brand. Both have good long warranties and stand behind their products.
    12-28-2015 08:55 AM
  4. parthtc09's Avatar
    I haven't had any issues with using older cables, only thing is the longer ones (10ft+) sometimes have issues.
    12-28-2015 11:48 AM
  5. mrtonk's Avatar
    FYI, there is a quick charger on sale at Amazon for only $6 at the moment.
    Tronsmart's Turbo Wall Charger is just $6 at Amazon with coupon code http://www.androidcentral.com/tronsm...on-coupon-code
    12-28-2015 12:08 PM
  6. Phoenix212's Avatar
    I bought that exact charger recently (stocking stuffer for myself) and used it for the first time this morning. Completely worth the $6. 18 month warranty through Tronsmart.
    12-28-2015 01:15 PM
  7. RETG's Avatar
    After rearranging the bedroom, the Motorola supplied cable was too short. Found an older one in the misc. wire box I have in the garage, and it works great. Unless you go really cheap, the majority of all USB plugs are the same. (Cords, not power supplies with cords; that a different animal!)
    01-03-2016 08:08 AM
  1. Phone freezing for a short duration on a regular basis!
    By whitten66 in forum Samsung Galaxy S6
    Last Post: 02-12-2018, 10:51 PM
  2. Replies: 8
    Last Post: 07-11-2016, 10:15 PM
  3. Who do I contact for a return?
    Last Post: 12-28-2015, 02:33 PM
  4. When is the Lollipop update for the Blu Studio G Coming?
    By IISlay_QueenII in forum Android 5.0 Lollipop
    Last Post: 12-28-2015, 01:58 PM
  5. Android 6.0.1 Beta probably released by mistake for the Galaxy S5
    By systemofadown1 in forum Samsung Galaxy S5
    Last Post: 12-28-2015, 12:53 PM
