Save big + get 3 months free! Sign up for ExpressVPN today
  1. ioorabh's Avatar
    Hello
    I have been using the phone since oct 2015,
    The phone is excellent in terms of battery.. Atleast over a day
    Last night I slept around 2AM with 75% batter my left, all apps off, WiFi off.
    But was shocked to see the phone was discharged morning 7am.
    I am attaching the screenshots
    Pls help me find the root cause thx. This is FIRST time it happened.
    U can see the draining in the chart.. I am scared.
    01-14-2016 07:55 PM
  2. ioorabh's Avatar
    Hello
    Attaching screenshots for the above issue mentioned.
    Attached Thumbnails Moto Turbo Battery drained suddenly-screenshot_2016-01-15-07-24-37.jpg
    edistopre likes this.
    01-14-2016 07:56 PM
  3. leehardballer12's Avatar
    Looks like something going on with that 'mobile security' app...
    01-15-2016 12:32 AM
  4. ioorabh's Avatar
    The app has been there since long.. But the issue occured only yesterday. Will shut down the app and check if anything changes.
    Thx
    01-15-2016 01:38 AM
  5. doogald's Avatar
    I told you in the other thread where you posted: unless you are installing apps that aren't from the play store, or are surfing porn sites or sites that offer "free" videos or something like that, you don't need a security app. Uninstall it unless you real live on the edge.
    Also, plug in your phone while you sleep so you wake up with a charged phone. One reason is just in case something like this happens, another is it is better for the battery to get a lot of small charges rather than a smaller number of big ones. That apparently can't be said too often.
    01-15-2016 07:00 AM
  6. 1Coopgt's Avatar
    My phone had some issues Wednesday for no reason and started draining the battery for no reason that I can figure out . Phone is fine now go figure .
    01-15-2016 05:15 PM
  1. Facebook draining battery
    By jaleelhamid in forum Android Apps
    Last Post: 01-26-2016, 09:00 AM
  2. Should I open Battery optimisation?
    By khing blue in forum Android 6.0 Marshmallow
    Last Post: 01-15-2016, 10:34 AM
  3. Note 5 Sprint battery drain, what could it be?
    By AC Question in forum Hardware Hideaway
    Last Post: 01-14-2016, 07:08 PM
  4. Is the Moto X Push to Talk Compatible?
    Last Post: 01-14-2016, 06:57 PM
  5. Samsung Galaxy S4 16 gb sd card is suddenly blank?????
    By AC Question in forum Samsung Galaxy S4
    Last Post: 01-14-2016, 05:08 PM
