1. gregba's Avatar
    Has anyone taken theirs apart before?
    My turbo had water damage and wouldnt work and my wifes turbo has a busted LCD screen. She was able to get a new phone and keep her turbo so I took both of ours apart to switch her motherboard into mine. I am having the hardest time trying to reconnect the LCD screen to the motherboard. Anyone have any tips?
    I can get it to power up, but I cannot get the screen to work.
    Thanks!
    01-16-2016 01:57 PM
  2. Einsteindks's Avatar
    You pull the screen connection out, or flip up the release bar?
    01-16-2016 01:59 PM
  3. gregba's Avatar
    Not sure, I wasnt sure that I even got the screen connection right. Does it slide into something, or just rest on something?
    01-16-2016 02:29 PM
  4. Einsteindks's Avatar
    The white part flips up, then the ribbon slides in up to the line. It's a little tight/tricky to hold it inserted while the white bar is pressed rotated down.
    7:35 in,
    gregba likes this.
    01-16-2016 04:02 PM
  5. gregba's Avatar
    thank you!!
    now I have it where when I plug it in only the green LED light is on. Its been charging for over 5 hours.
    I cant take this SGS3 much longer...
    01-17-2016 07:51 PM
  1. On the fence about getting one, help.
    By Bridey1 in forum SHIELD Tablet
    Last Post: 01-27-2016, 02:32 PM
  2. Is the G4 still a good buy?
    By MSFTisMIA in forum LG G4
    Last Post: 01-18-2016, 09:35 PM
  3. How do I remove the cyberpolice virus scam from my LG?
    By dennisbracy in forum LG Android Phones
    Last Post: 01-17-2016, 03:33 AM
  4. Mystery icon on the status bar
    By nex6p in forum Nexus 6P
    Last Post: 01-16-2016, 02:23 PM
  5. How do I undo the remote lock for this device?
    Last Post: 01-16-2016, 01:03 PM
