1. ffactoryxx's Avatar
    I have had this phone for over a year and suddenly in the last two weeks the battery drains like crazy. Trying to think if anything installed between then and now. Only thing I can think of is turning nfc on two weeks ago for some reason.
    01-22-2016 03:16 PM
  2. Davidoo's Avatar
    I have noticed something similar in the last 2 weeks. I've had excellent battery life since I got the Turbo on day one back in 2014. Usually I will go to bed after a full day's use and put it on the charger with around 60% left. Over the last 10 days or so, with the same use, I'm down in the 40s each day. I can't see anything different, although of course a lot of apps have updated since then. Still great battery life. Maybe the battery is just showing age.
    01-22-2016 06:08 PM
  3. TiMar99's Avatar
    Randomly I'll notice my battery draining like crazy, a simple reboot solves whatever the issue was. This happens a few times a month I've noticed.
    01-23-2016 01:45 PM
  4. ryanidcomm's Avatar
    I have better days and worse days.. a FDR is annoying but will solve any software issues. or start deleting apps you havent used in 2 weeks
    01-27-2016 07:07 PM
  5. leehardballer12's Avatar
    I have to make sure to keep the brightness down. Whenever I notice my battery draining abnormally fast, its almost always that I forgot to turn the brightness back down.
    01-29-2016 09:31 PM
  6. tony bag o donuts's Avatar
    I found where I work my desk is one of a few that just don't get a strong wifi signal so I turn it off. If I don't battery drains pretty fast.
    02-01-2016 07:28 AM
  7. sethgoldstein's Avatar
    I noticed that Snapchat and using the camera used the battery a lot.
    02-07-2016 12:51 PM
  8. nedqadams's Avatar
    Yes the last two-four weeks its gotten worse. Newsblur was using up the most of it so I removed it. Will have to see if that makes a difference but it's possibly a shortened battery life with the quick charge charging cycle. Need to find out info on a battery replacement program.
    What's odd is I just noticed I charged from 3:30am last night until 9:00am this morning and yet only went from 30% to 70%. That doesn't seem right. 5 Hours should be more than enough to charge the phone and yes I was on turbo unless it was one of those times the charger doesn't recognize the turbo element.
    02-16-2016 11:22 PM
  1. Replies: 1
    Last Post: 01-24-2016, 04:25 PM
  2. Why is my phone draining its battery so fast?
    By AC Question in forum Batteries
    Last Post: 01-24-2016, 04:20 PM
  3. "Phone" Category Battery Drain
    By BuckeyeNut25 in forum Sony Xperia Z3v
    Last Post: 01-22-2016, 11:56 AM
  4. Good idle battery life
    By dpham00 in forum Honor 5X
    Last Post: 01-22-2016, 10:05 AM
  5. Kik Drains Battery ???
    By Kevin Christof in forum Ask a Question
    Last Post: 01-22-2016, 09:03 AM
