1. AC Question's Avatar
    When posting in fb I cannot find any emoticons other than a sticker which is huge.
    02-08-2016 11:39 AM
  2. Rukbat's Avatar
    Emoticons are usually on the keyboard. If the one you're using doesn't have any, look in the play store for one that has a set you like. (There's no "standard" set - some keyboards use the Apple set, most use their own.)
    02-09-2016 05:53 PM
  3. KSDroid01's Avatar
    If you're using the stock Turbo keyboard, hold down on the backspace button (lower right) then slide up to the emoticon button that will appear above it.
    Posted via Moto Turbo
    02-09-2016 09:59 PM
  1. Replies: 7
    Last Post: 02-09-2016, 11:49 PM
  2. People hear echo when on the phone.
    By andonakis in forum Nexus 6P
    Last Post: 02-08-2016, 08:26 PM
  3. How do I flash OmniROM 5.1.1 on GT-I8190N?
    Last Post: 02-08-2016, 01:49 PM
  4. Replies: 3
    Last Post: 02-08-2016, 11:57 AM
  5. Replies: 0
    Last Post: 02-08-2016, 11:18 AM
