1. 1901Madison's Avatar
    Hi all. In terms of screen on battery life, the Turbo is the best phone I've ever owned. But the idle drain is so much higher than any other phone I've used. It drains 1% per hour when not being used, even on airplane mode. It's almost as if something is running even when all apps and radios are off. Does anyone else have the same experience? Any fixes?
    02-20-2016 06:51 AM
  2. Einsteindks's Avatar
    GPS can still be active in airplane mode, and looking/keeping a lock on those little buggers can be taxing. Something could be trying to keep your location. Any apps in RAM could be it. If found, consider wiping at least app cache, and maybe even app data.
    02-20-2016 07:30 AM
  3. PowrDroid's Avatar
    I would consider a 1% idle drain as being acceptable. I don't have any recommendations except to say that the Doze power saving function in Marshmallow should improve this.
    mrtonk likes this.
    02-20-2016 09:23 AM
  4. 1901Madison's Avatar
    Thanks! Do you think this is possible even if I have my GPS/location seeing turned to off?
    02-20-2016 10:18 AM
  5. Einsteindks's Avatar
    Not sure. I'm no expert, just an amateur who's dabbled here and there. Could also be wake-lock, and there are apps that sniff those out.
    02-20-2016 11:02 AM
  6. T79phoenix's Avatar
    I would think that 1% an hour would be sufficient. Think of it this way. 1% an hour would only lower your battery to 76% in a full 24 hours. Take that number and you can get 4 days straight out of it.
    They do claim with periodic/normal/moderate use it can get about 2 days (which I haven't seen with my T2) but with the rate you're going, you could do just that.
    doogald likes this.
    03-19-2016 10:13 AM
  7. 1901Madison's Avatar
    You're right. And as my battery settled in, I've noticed it going through an 8 hour night and only losing 3%. That's really good! Very happy with this improvement.
    T79phoenix likes this.
    03-19-2016 04:18 PM
  1. Why is my brand new Droid Turbo 2's battery draining so fast?
    By AC Question in forum Motorola Droid Turbo 2
    Last Post: 02-21-2016, 09:56 PM
  2. Samsung galaxy note 3 battery drain
    Last Post: 02-20-2016, 04:47 AM
  3. Powering down without warning and then optimizing apps for 10+ minutes.
    By kevinbridges71 in forum Motorola Droid Turbo
    Last Post: 02-20-2016, 01:52 AM
  4. LG MS395 Power Issue
    Last Post: 02-19-2016, 11:34 PM
  5. Replies: 0
    Last Post: 02-19-2016, 02:31 PM
