1. AC Question's Avatar
    OK so I bought a turbo online, everything worked great. Well about two weeks ago I was talking on the phone while it was on speaker. It went really quiet and distorted. I have tried to replace the speaker once but I believe that one was blown already. I have a new one coming today, but if that doesn't work does anyone know what it might be?
    04-13-2016 09:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is sound normal through wired or Bluetooth headphones? If so, then it's most likely a damaged speaker, as you suspect. What do you mean when you say you've tried to replace the speaker once but you believe that one was blown already? Do you mean that you actually replaced the speaker in the past 2 weeks, but you think the replacement speaker was blown as well?
    04-14-2016 03:07 AM
  1. LG lg3 phone I have to place it on speaker to talk!! HELP
    Last Post: 04-13-2016, 12:42 AM
  2. Replies: 1
    Last Post: 04-13-2016, 12:26 AM
  3. Sudden freeze and "fog horn" sound on my gs7e
    Last Post: 04-12-2016, 05:29 PM
  4. Man! That sounds soooooo sweet!
    By dwmitchell61 in forum LG V10
    Last Post: 04-12-2016, 05:10 PM
  5. Notification Sounds Playing on Mute/Silent
    By TenshiNo in forum Samsung Galaxy Note 5
    Last Post: 04-12-2016, 01:32 PM
