1. cb2367's Avatar
    I have a few numbers saved in the speed dial. Other numbers I frequently call are listed. I'm dialing a number from the speed dial and it's going out as assisted dialing (001-area code and number). I was just recently in a foreign country, but didn't make any calls. The phone has been off while traveling and was turned on once back in the states.
    Now EVERY number I call is going out as 001-area code and number. The only way to make a call is to manually enter the number.
    I'm trying to get help from Verizon, but I don't think they've seen the issue before. Can anyone help with this?
    06-15-2016 12:48 AM
  2. doogald's Avatar
    Assisted dialing, I think they call this.
    I don't have a Turbo, but does this help?: [Q] Changing the default Country code that g… | Verizon Motorola Droid Turbo
    Call Settings > Assisted Dialing > Reference Country
    1. Press and hold the country you want to set it to
    2. You will get an option of "change reference", "View details"
    3. Click on "Change Reference"
    4. Hit back until you exit.
    (I believe he means open the three dot menu in the dialer/phone app when he says "Call Settings".)
    06-15-2016 05:29 AM
  3. cb2367's Avatar
    Checked those settings and it indicates that the current country is Panama (which is where I was), but I'm back in the U.S. now. Reference country is U.S.
    06-15-2016 07:33 AM
  4. doogald's Avatar
    I'm on the road in a moment, so hard to look into this, but maybe there's an issue with the sim? Try going to a Verizon store for a new one, which they will activate to your account, and see if that fixes it.
    06-16-2016 09:57 AM
  1. Replies: 4
    Last Post: 01-23-2017, 02:34 PM
  2. Spec showdown with other flagships
    By srkmagnus in forum OnePlus 3 & 3T
    Last Post: 06-15-2016, 12:43 AM
  3. Phone locked itself with android device manager
    Last Post: 06-15-2016, 12:18 AM
  4. Replies: 0
    Last Post: 06-14-2016, 11:23 PM
  5. 12040#9345646 found in call logs what kind of number is this
    Last Post: 06-14-2016, 11:14 PM
