1. this_is_nascar's Avatar
    What do the different colors of the Mobile network signal of this graph represent?
    06-18-2016 01:18 PM
  2. Javier P's Avatar
    They represent signal strength, being green the best and red nonexistent. Orange means bad signal and that brown you get is kind of weak signal, about 2-3 bars.
    06-18-2016 03:29 PM
  3. this_is_nascar's Avatar
    Thanks.
    06-19-2016 06:56 AM
  4. 1201ExecOverflow's Avatar
    How do you get that screen back, the updates took that screen away and replaced with a crappy new screen that doesn't show how many hrs/secs you have been running, nor the graphs you mentioned?
    06-27-2016 10:38 AM
  5. Javier P's Avatar
    Welcome to the forums. It looks like he's still using KitKat or some module. After Lollipop the background for that screen is white and you can get it if you tap on the main battery graph. Doesn't work for you?
    06-27-2016 10:55 AM
  6. this_is_nascar's Avatar
    Correct. I've never taken the upgrade. I'm too frightened to do so, since everything is working the way I like it right now.
    08-03-2016 06:19 AM
  7. this_is_nascar's Avatar
    Only thing in finding is that my battery life is shortening.
    08-03-2016 06:20 AM
  1. Battery % reducing drastically when it is under 10
    By srinathp1988 in forum Samsung Galaxy Note 5
    Last Post: 07-02-2016, 01:23 AM
  2. Battery life problems with the screen
    By Arnaud Saget in forum Samsung Galaxy S7 edge
    Last Post: 06-21-2016, 08:52 AM
  3. Replies: 1
    Last Post: 06-18-2016, 01:07 PM
  4. System ui errors when below 15% battery
    Last Post: 06-18-2016, 07:30 AM
  5. Replies: 1
    Last Post: 06-17-2016, 11:00 AM
