1. Greg Brennum's Avatar
    I have a Droid Turbo with a broken power button. Unfortunately after a day of beverages, I let the battery die and am now unable to turn the phone on. Searching various forums for a solution, I came across someone who said that if I use a wireless Q1 pad/stand, the Turbo will turn on without the aid of a power button while charging, thus solving my problem. Can anyone verify that before I go that route? Thanks!
    06-27-2016 08:23 PM
  2. dnwhome3's Avatar
    It always has for me. You could probably try it on yours in the store.
    Greg Brennum likes this.
    06-27-2016 09:18 PM
  3. Greg Brennum's Avatar
    Does your Turbo turn on when charging with a normal wall charger? Mine never has and it is the only phone I have had that does that.
    06-27-2016 09:28 PM
  4. dnwhome3's Avatar
    The original Motorola Droid would turn on when charging by cord.
    The Droid Turbo has some battery charge level indicator if it was off when the charging cord was plugged in. But it boots the phone normally if its off and put on the wireless charger.
    06-27-2016 09:34 PM
  5. Greg Brennum's Avatar
    No, only the wireless.
    Thanks for your help. Might as well make the purchase. Either way, its cheaper than buying a new phone.
    06-27-2016 09:37 PM
  1. Need to connect device that is not recognized
    Last Post: 06-29-2016, 08:43 AM
  2. Is the S7 Edge compatible with the AllShare Cast Wireless Hub?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 06-27-2016, 10:42 PM
  3. Replies: 0
    Last Post: 06-27-2016, 12:59 PM
  4. Need an App that adds text in "Sparkle" Font(s)
    By MuchObliged in forum Tablet Apps
    Last Post: 06-27-2016, 12:12 PM
  5. Replies: 0
    Last Post: 06-27-2016, 11:02 AM
