1. sn8kman1's Avatar
    I see a lot of people that are not able to get connectivity of apps on WiFi, but I have the exact opposite problem. When I'm on 4G, none of my notifications work (Twitter, Gmail) until after I connect to a WiFi network, then they come through. If I open the apps while in 4G then I see new messages and such.
    Also, Google Photos and my Google Calendar don't sync when in 4G, and this free app Inkpad won't sync with the website over 4G either. I've checked settings and everything appears to be okay. This is what I do Settings-->Data Usage-->Mobile Data is slid to on. I've also gone into App Info by holding the app and can't see any options there.
    I've uninstalled and reinstalled and same issue.
    Ideas?
    07-04-2016 05:10 PM
  2. B. Diddy's Avatar
    Check in Settings>Data Usage to make sure Restrict Background Data isn't turned on.
    Also, do you have any 3rd party apps (from Verizon or elsewhere) that might be controlling your mobile data (to help you from going over your data cap)?
    07-05-2016 01:29 PM
  3. sn8kman1's Avatar
    Check and no, no background apps that I'm aware of. Unless they are in my app drawer. I don't have any active ones.
    07-05-2016 02:39 PM
  4. B. Diddy's Avatar
    How about something like "My Verizon," or an app that allows you to check your Verizon account?
    07-05-2016 02:43 PM
  5. sn8kman1's Avatar
    Yes, I do use that app. What could that have to do with it though?
    07-05-2016 07:55 PM
  6. B. Diddy's Avatar
    Some carrier account apps include features that are meant to help you monitor or limit your data usage (which can obviously be useful if you have a relatively small data plan, but which can be a pain if you have lots of or unlimited data). Check through its settings to make sure there aren't any features like this. (Sorry, but it's been a while since I've looked at a My Verizon app, so I just can't be sure.)
    I looked over at the Verizon site--do you have FamilyBase? Set Data Limits - FamilyBase - Android | Verizon Wireless
    07-06-2016 02:15 AM
  7. sn8kman1's Avatar
    Thanks for the help. Followed your link and it said there are no safeguards in place. Any other ideas?
    07-06-2016 11:55 AM
  8. B. Diddy's Avatar
    Have you already asked Verizon about this?
    07-06-2016 05:05 PM
  1. HTC10 Issues/Problems
    By HnLA in forum HTC 10
    Last Post: 07-13-2016, 06:50 AM
  2. connect damaged turbo to tv & remote keyboard
    By mikeypop1948 in forum Motorola Droid Turbo
    Last Post: 07-08-2016, 08:59 PM
  3. No USB connection after last upgrade
    By metrov in forum Samsung Galaxy S5
    Last Post: 07-04-2016, 03:47 PM
  4. Issue with "actually free" apps
    Last Post: 07-04-2016, 01:35 PM
  5. Samsun S4 MIc issue...Help
    By raceware in forum Verizon Samsung Galaxy S4
    Last Post: 07-04-2016, 10:01 AM
